New build, help with cooling and choice of case and Psu
Solved by LienusLateTips,
14 minutes ago, Sanctorum said:Okay, well again, I've built a custom loop in an Enthoo Pro M, which is the same case as the P400S internally. Put the rad up top and you're good to go.
Yes but externally there is a lot more airflow on the Enthoo Pro M.
Featured Topics
remo233 ·
Posted in Power Supplies1 -
VioletGiraffe ·
PietervdWiel ·
Posted in New Builds and Planning7 -
9
DaveNoir ·
Posted in Troubleshooting0
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
