Need a rear exhaust fan gpu for my itx PC
Guest
FIXED Right now I have a gtx 1070 strix, and it is at 80'c and the hdd next to it is 56 degrees max, (but it is a server hdd, toshiba p300 4tb) Crystaldiskinfo says that 56 degrees is bad. So im considering a rear exhaust card, because right now too much heat is going into my case, sharkoon itx c10. So should I do something with my case cooling or buy a rear exhaust cooling card?
How many fans and which fans do you have in the system currently?
some sharkoon 120mm running at full speed and arctic f8 pwm running at 1700 rpm. The problem is that the harddrives are far from the airflow.
I partly fixed the problem by replacing my Arctic f12 pro pwm with generic sharkoon, and installing gpu tweak and disabling silent fans. The arctic f12 pro is a great fan, as silent as noctua, but it doesnt perfome great in itx case, it is more of a airflow fan, not static pressure, so it didnt move air in my tight case.
