Vega 64 Desktop temps and power (non-game)
tridy
Hi.
How much power does it consume and what are the temperatures of Vega 64 are when running:
1) Desktop apps (office, browser, youtube videos)?
2) HTPC mode (lets say 4K BRRip video in KODI)
would it be relevant to count how much power a video card consumes if I want to keep the PC "on" most of the time, without any heavy tasks?
and if we compare that to the power consumption of 1080 and 1080Ti in Desktop, will there be much difference?
Thanks!
Are you buying it to use for office work? The only power consumption that really matters is the max, and electricity is so cheap most places it doesn't make that much of a difference. On idle, it'll probs be pretty low, just like any other GPU.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
Power draw = too much
Vega 56 = 210 Watt's
Vega 64 = 295 Watt's
And vega 64 Liquid cooled = 345 Watt's
Damn that power usage
Tag me if you need me :D
Desktop:                                       Laptop:
CPU - i7-4790k                            CPU: I7 7700HQ
GPU - Inno3D 1080TI                  GPU: 1060
Mobo - Gigabyte Z97X-SLI          Memory: 16 GB
Memory - 32 GB DDR3                Storage: 1256GB
Storage - 11 TB
Phone: ONEPLUS 6 128GB
OP is askin about idle temps...
Want to custom loop?  Ask me more if you are curious
For home, but I often work from home and keep the computer on most time, doing usual desktop tasks, and programming.
10 minutes ago, lots of unexplainable lag said:
Literally watch the reviews on it. Basically everybody goes into the power draw aspect.
Will it be the same as "idle" temps?
idle temps maybe 25-35*c? my 1080ti produces that kind of result when not in use. so i guess it'll be the same. one way or another... i can't find a reviewer that discussed "idle temp" as of yet :S
CPU: Intel Core i7-7700K | Motherboard: ASUS ROG STRIX Z270H | Graphics Card: ASUS ROG STRIX GTX 1080 Ti OCEdition | RAM: 16GB G.Skill Ripjaws V 3000MHz |Storage: 1 x Samsung 830 EVO Series 250GB | 1 x Samsung 960 PRO Series 512GB | 1 x Western Digital Blue 1TB | 1 x Western Digital Blue 4TB | PSU: Corsair RM750x 750W 80+ Gold Power Supply | Case: Cooler Master MasterCase 5 Pro |
Cooling: Corsair H100i v2 // 4x Corsair ML140 RED Fans // 2x Corsair ML120 RED Fans
Monitor: ASUS ROG Swift PG279Q 1440p 165Hz IPS G-Sync | Keyboard: Corsair K70 LUX Red LED, Cherry MX Brown Switches | Mouse: Corsair Glaive RGB | Speakers: Logitech Z623 THX Certified Speakers
actually "idle power consumption" with 2 x 4K monitors in Desktop would be really interesting.
Are you gonna game or use GPU intensive tasks?
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
Why are you even buying a high-end card in the first place for those basic task? Even onboard will be sufficient enough. If not, get like a GTX 1050.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
roughly
15% gaming
85% programming, office, browsing
I want to game (and my son as well) but I have to work Mon-Fri, sometimes from home.
AMD ThreadRipper 2!
Thanks for the info.
would it translate the power consumption accordingly?
13 minutes ago, tridy said:
roughly
15% gaming
Hmmm.... I doubt the GPU will take much power on idle, and unless your electric is really expensive, it won't be enough to notice.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
Should I see
2 x 1200p in Desktop
vs
2 x 4K in Desktop
as more or less equal "idle"?
power consumption and temperature are 2 completely different things.
17 minutes ago, tridy said:
Should I see
vs
2 x 4K in Desktop
Idle means the computer is just ON (like you turned it on and it's finished booting up all the way, but you aren't using it yet, that is what Idle is), your display setup doesn't redefine IDLE, idle is a state of being, not a configuration.
Whoops :D
Desktop:                                       Laptop:
Storage - 11 TB
:) what i meant that the difference/ratio in temperatures would match the difference in power consumption.
I thought that "idle" is when the computer booted and it is just the OS that is running, and you are not doing anything for like 10 minutes, and then you measure the temps.
I will legit test my Vega 64 system with 2 4K panels plugged in it and attach a image of power taken from the socket.
System is quite heavy on peripherals however.
That would be great, thanks!
116W from the socket.
Thats with a Ryzen 1700 with an AIO and 5 fans.
It also has 2 SSDs and 2 HDDs.
ok, that is not bad at all! That includes 2 monitors as well.
Thanks a lot!
That is just the system on its own.
My 4K panels use 30W each.
