Up to you. If you want to show off your pc I would.
PC: Case: Cooler Master CM690 II - PSU: Cooler Master G650M - RAM: Transcend 4x 8Gb DDR3 1333Mhz - MoBo: Gigabyte Z87x-D3H - CPU: i5 4670K @ 4.5Ghz - GPU: MSI GTX1060 ARMOR OC - Hard disks: 4x 500Gb Seagate enterprise in RAID 0 - SSD: Crucial M4 128Gb
Phone: Samsung Galaxy S6
Im gonna say yes because ive just done it haha.
Got some new sleeves cables and AIO sleeving. I have bought stuff from there before and never had any issues. They customer service is pretty good too.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
Sure, they have great customer support and their stuff is generally regarded as quite high quality, they even have a rep on this forum
Builds:
14 minutes ago, Krik00 said:
So is it satisfactory? :D
already have LEDs :D
Can only comment on the cables so far as not moved my build to the new case and used all the new shinny things. Cables wise... yeah they are great. :)
If you can, I don't see why not, they're a nice option to make your rig look nice. Another option would be to buy sleeving and sleeve the cables yourself, if you want to save money and have lots of time to do it.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
7 hours ago, Krik00 said:
I am considering to buy some thumbscrews, AIO sleeving and cable extensions. It would cost me 80 USD with 20 being shipping. Should I go for it, or nah?
@Krik00 check out Performance-PCs - you'll find our products there with cheaper shipping options available. You can also check on Amazon. :)
@Nosfy would love to hear some feedback from you on the new AIO sleeving kits! Would you mind emailing me at Matt@CableMod.com?
Shipping to Slovakia from Performance PCs would cost 40-110 bucks, so 20 is good enough :D I will write a review once I will test the sleeving as well :D
Hi Matt.
No problem. Should be moving into the new case this weekend so will drop you an email.
CableMod cables are great!
I've got their power cables, ethernet cables, and PSU cables :D
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
@CableMod so far so good. The clips on the AIO sleeve are a bit annoying to put on, other than that its looking good.
3 minutes ago, Krik00 said:
That's not Kraken x62 :D
No, I literally change it yesterday. Not update my new details yet :P
Kraken didn't fit at the top and I don't like rads at the front so got the Hi100i v2
