Correct NiMH battery charger
Solved by mariushm,
No problem.
niMH batteries are 1.2v nominal, ~ 1.35v when fully charged.
The voltage has to be higher than max voltage to charge so 1.4v per battery (2x1.4=2.8v) is perfectly reasonable.
You can learn more about NiMH batteries here: http://data.energizer.com/pdfs/nickelmetalhydride_appman.pdf
Featured Topics
Newbietobe5467 ·
Posted in Cases and Mods1 -
1
3
2
Avallyn ·
Posted in New Builds and Planning2 -
2
me255 ·
Posted in New Builds and Planning10
