2 minutes ago, TheComputerdude said:
run a virus scan or monitor CPU usage during gameplay if it is hitting 100 and something besides gtav is taking up a bunch of power that could be a culprit
nothing is maxed at all. gpu lowww cpu not very high at all. ram pretty high,
nothing maxed out though
vsync is on?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
4 minutes ago, TheComputerdude said:
can you list all of your settings
7 minutes ago, JDE said:
vsync is on?
16 minutes ago, leelaa14 said:
Lower grass setting and make sure advanced graphics settings are turned off.
http://prntscr.com/gam7pj
http://prntscr.com/gam7y2
http://prntscr.com/gam81x
http://prntscr.com/gam84j
there you go :D
26 minutes ago, Will01 said:
what is the average fps you are getting ??? and try turning tessellation and maybe a couple of other settings down a bit
i shouldnt have to turn settings down though :( not that much anyway.
not sure average, sometimes its fine sometimes it can be like 20
Your VRam isnt enough for max settings.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
at the settings im at my vram is not maxed. im not at maxed settings. pretty high though. nothing is maxed. cpu usage like 60% ram like 80% gpu usage like 35% and vram is at 2800mb in gpu-z
What are your driver settings?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
47 minutes ago, Will01 said:
what do you mean by driver settings sorry?
Your Nvidia driver settings
23 minutes ago, Will01 said:
For gta? i dont know what nvidia driver settings are
Right click on your desktop and open your Nvidia control panel
ah okay. Ive actually just watched a video online about changing some settings in the manage 3d settings section. here are the screenshots. Im going to go and see if my fps has changed after changing these settings. thanks again
http://prntscr.com/gb9svm
http://prntscr.com/gb9t0z
Run the benchmark test and see what’s your average FPS.
I have a GTX 1060 as well (albeit on a laptop and with 6GB of VRAM instead of 3GB) and my average tends to be around 50 and max is about 80 in open, less-dense areas.
I know the 1060 shouldn’t be dropping to the 20s with settings this low.
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
