I have a decent pc. ryzen 5 1400 and a gtx 1060 8gb ddr4. After playing for a while i get fps drops and it can get pretty bad to the point where i have to restart the game and once done its fine again. ez solid 60 fps. not sure why it does this but the game is unplayable unless im restarting quite a bit.
https://linustechtips.com/topic/818248-gta-5-lag-problem/
1 minute ago, Kabooom said:
Might be a server error at rockstar. I was lagging a bit too.
anything going down at rockstar should have absolutely zero effect on clientside FPS.
it may cause rubberbanding, but its not gonna impact fps.
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10257846
Whats your system memory and vram usage when this problem occurs?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10257866
You surely have ran out of VRAM in GTA V several times and that caused the lag.(It is mainly caused by the lack of VRAM given by the video card)
If your 1060 has only 3gigs of Vram then that's the reason why you are lagging.
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10257931
40 minutes ago, manikyath said:
what are temperatures like? and what other stuff do you have running?
forgot to quote sorry. look above
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10257975
In order to lower the VRAM you'll have to lower the graphics settings in GTA V. Most likely the one with the textures will reduce the usage of V-RAM. Please check it by yourself in the graphics menu. I can't really open up the game to check by myself.(sorry)
TO BE UPGRADED:
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10257996
gta shows you vram usage, so lower settings and see which affect vram usage and turn those down
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10258046
right now my vram on gta is like 2500mb out of 3000mb so i should be good!
Do you think it could be to do with me only having 8gb of ram? my ram usage is pretty high but surely 8gb is enough to play gta!!!!!!
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10261869
8gigs of ram is enough at this very moment for gaming. Some games require more than 8 for 'a better experience', tho. (F*CKING FORZA HORIZON that requires ~12gb to run smoothly)
TO BE UPGRADED:
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10262344
yeah, thats what i was thinking. Im just annoyed and confused why i cant play gta 5 properly with such an expensive pc. i know it could be alot more with a threadripper plus 1080ti but for the ammount ive spent this pc should be able to run gta 5 high settings with ease surely! i feel like ive either done something wrong or theres a glitch or something. i just dont know anymore. im heading to rockstar support now. they are really bad so it will probably be a waste of time. but oh well
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10262692
Then your GTA might be the issue, because I have tried to play GTA V today and with everything on very high and works fine. It doesn't run 60fps 24/7 but it's playable and kinda smooth sometimes. But you know, each gamer has his opinions when it comes to FPS and smooth gameplay.
TO BE UPGRADED:
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10263801
ok. and no offence but you only have a 1050ti and 880k. i think it might be my game. thanks again
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10263924
I know I "only" have those but at the time when I upgraded Ryzen was not available for me and I didn't want that G4350 from Intel. I know I literally fucked it up but now I am planning to sell this one and upgrade to Ryzen.
TO BE UPGRADED:
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10263991
  • 2 weeks later...
Just now, Will01 said:
I have a ryzen 5 1400, 8gb ram, gtx 1060 3gb and a 430w psu
I get really poor fps in gta 5. I have the latest drivers and the vram is not a problem. the bar in the gta 5 settings is in the green!
Lower grass setting and make sure advanced graphics settings are turned off.
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10324198
ok, is this a thing that affects even really good pcs? does this affect you?
i think because VRAM
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10324202
run a virus scan or monitor CPU usage during gameplay if it is hitting 100 and something besides gtav is taking up a bunch of power that could be a culprit
https://linustechtips.com/topic/818248-gta-5-lag-problem/#findComment-10324217
