Problem? mounting dark rock 3
stevenh
Hello, I'm trying to mount my new dark rock 3.
But the back plate is touching some of the solder pins on the back of the mother board.
Is this a problem or should it work fine?
The part of the backplate wich touches the solder seems to be some kind of foam
Phanteks Enthoo Evolv ATX | Intel Core I-5 8600K | Asus ROG Strix Z370-F | Asus ROG Strix 1080 8G | 16gb 3200mhz CL16 G.Skill Trident Z RGB | be quiet! Dark Rock 3 | Samsung 850 EVO 250GB SSD |  EVGA Supernove G2 750W |  WD Blue 1TB | WD Green 4TB |
7 minutes ago, NoobCase said:
The foam is there to insulate so you should be fine. But pictures would be very nice to make sure before we advice you to turn on the pc
Ik atached the picture DSC_0134.thumb.JPG.3e602c27fdc4eec604e0c6f36a89d315.JPG
23 hours ago, stevenh said:
  Reveal hidden contents
Just as its supposed to work. Some use rubber washers for same thing.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
