Hello!
Before i explain my problems i want to say that this is not my native language so ask me if you dont understand something.
Also i suppose you have to know my build so here it is:
   -Phanteks Eclipse P400S White
   -I7 6700k @ 4.00Ghz - 1.2v (??)
   -Gigabyte z270x Gaming K5 Aorus
   -Kingston Hyperx 2x8Gb 3000Mhz
   -GeForce GTX 1080 Founder Edition
   -NZXT Kraken x52
   -Corsair RM1000i
   -WD SATA 3 Red 2TB
   -Asus VG248QE 24'' 144Hz
   -Corsair Strafe RGB Cherry MX silent
   -Logitech G403 Wired
At the beginning i had at full load 90C temps so i decided to undervolt my cpu in bios. So i went to voltage advanced settings and changed:
Cpu vcore: from (normal - 1,3v) to (Auto -1,2v)
LLC: from auto to standard
With this changes my temperatures went from 90C to 70C on full load but the voltages have peaks of 1.33v sometimes.
Because of that i decided to not undervolt my cpu even more (that wouldn't make any difference, for some reason).
I would like to now how to undervolt my cpu correctly so it wont pass the vcore voltage  (or at least not to much)
Thanks for any suggestion.
My PC
  • Tower:
-I7 6700k @ 4.00Ghz @ 1.2v
-NZXT Kraken x52
-Corsair RM1000i
-Samsung Evo 500GB
-WD SATA 3 Red 2TB
  • Peripherals:
https://linustechtips.com/topic/810303-undervolting-i7-6700k-issues/
You have something wrong with your cooler. Re-install it and replace the thermal paste. That chip should never hit 90C on water. Also no one would undervolt a K CPU. The whole point of those it to turn the voltage up for overclocking.
Be careful if you are monitoring the actual voltage passed, or the VID which is what the CPU thinks it wants, but doesn't necessarily get. The CPU doesn't actually report the voltage and you have to rely on the mobo.
90C does sound excessive, and may be a mount thing. Under what load do you get those temperatures? Also make check if the mobo might do some core optimisation for you, usually in the form of all cores to 4.2 GHz overclock as it usually boosts voltages a bit to do so.
Undervolting and overclocking are two aspects of the same thing, just in opposite directions. In my experience, 1.25V is ok at 4.2 GHz under Prime95 but it may go unstable at lower voltages. Less stressful loads might get away with less. Auto on mine tends to be over 1.3v.
The cooler is fine is just the voltage, im sure. It was 90C under a prime95 stress test before i changed the voltage, then it went down to 70C.
I think is what porina said, maybe i looked at the vid.
Also i didnt say that i disabled the turbo boost, because it was always active (at idle too). Now the cpu works with lower clock speed and voltages when i dont need it.
Btw, i decided to undervolt my cpu because of the high temps and the excesive voltage the cpu had. I will overclock it when i think i need it but now, 4ghz are ok.
EDIT: im not at home until august so I cant check if what you said is the answer to my problem.
My PC
  • Tower:
-NZXT Kraken x52
-Corsair RM1000i
-Samsung Evo 500GB
-WD SATA 3 Red 2TB
  • Peripherals:
I have my 6700k running @ 4.3 with 1.180V right now Auto LLC - Aida64 Test never goes over 79 and RealBench was 81 after running Aida64 for 1 hour all with the Cryorig H7
I would try 4.2 @ 1.2 on Manual mode , then go from there...
I7-6700K@4.3@1.180V - Asus Strix Z270E - 16GB Geil RGB DDR4 3000Mhz - Asus Strix 1070 8GB - Cryorig H7 - 120GB SSD INTEL - 1TB WD Blue - Corsair 650W
This is my bios after the first undervolt
http://m.imgur.com/account/ALP09/images/uCy0nu1
Now the settings are the same except:
-Vcore: 1,2v
-VCCPLL OC 1,09v
The results running xtu stress test is this:
http://m.imgur.com/account/ALP09/images/oXTiDCZ
But when im playing games i have peaks of 1,33v (idk if thats the real voltage or the VID i will check it when i arrive home). Hope it is the VID..
Btw what i should modify in the first picture?
Thanks for your quick answers!
My PC
  • Tower:
-NZXT Kraken x52
-Corsair RM1000i
-Samsung Evo 500GB
-WD SATA 3 Red 2TB
  • Peripherals:
My temps are fine (~70C running Prime95 heat test) but i cant ignore those voltage peaks.
My PC
  • Tower:
-NZXT Kraken x52
-Corsair RM1000i
-Samsung Evo 500GB
-WD SATA 3 Red 2TB
  • Peripherals:
-Vcore: 1,2v
-VCCPLL OC 1,09v
But when im playing games i have peaks of 1,33v (idk if thats the real voltage or the VID) i will check it when i arrive home. Hope it is the VID..
Might be me but your link aren't working..
VID = what CPU request
VCORE = what is been given
If your LLC is set to AUTO you might have big jump in Voltage , try testing with LLC @ 1 , then @ 5 ..
My PC
  • Tower:
-NZXT Kraken x52
-Corsair RM1000i
-Samsung Evo 500GB
-WD SATA 3 Red 2TB
  • Peripherals:
Links only works with Wi-Fi (for me).
My LLC is standard and my bios have 3 more options: auto, high and turbo.
Im gonna try to fix the links.
My PC
  • Tower:
-NZXT Kraken x52
-Corsair RM1000i
-Samsung Evo 500GB
-WD SATA 3 Red 2TB
  • Peripherals:
