More fans or more powerful fans
TheRedViper
So I have 3x 60mm thick radiators to cool (2x360 and 1x240). These would require high static pressure, but im in a dilemma between performance and noise. I am looking to combine Be quiet! Silent wings 3 with Noiseblocker E-loop fans to match the build. Thing is I can get the higher speed version of both to double the static pressure but it raises the noise level by around 75%. So I was wondering about your opinion on weither I should combine fans 2 and 4 in a push-pull setup or go with a better push or pull.
1) Be quiet! Silent wings 3 120mm PWM high speed:
73 cfm - 3.37 mm H20 - 28.6 dBa
2) Be quiet! Silent wings 3 120mm PWM:
50 cfm - 1.79 mm H20 - 16.4 dBa
3) NB E-loop B12-P:
78 cfm - 2.24 mm H20 - 28.4 dBa
4) NB E-loop B12-PS:
58 cfm - 1.48 mm H20 - 21.2 dBa
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
Why not use good fans in push/pull? Best of both worlds. You don't need to run high speed fans at full speed all the time anyhow, and they tend to scale similarly to their lower speed counterparts when slowed down.
I would go with the higher mmHg fans and decrease their overall speed until you get to an acceptable noise and temp level.
My choice would be #2 since those figures are likely at 100% speed and aren't likely to drop drastically around 50-60% speed.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
