I'm building my next gaming rig and i'm having trouble choosing a proper case to fit the noctua nd h15 .
I will run a i5 7600k , and my plan is to push it as higher as possible as long as the cooler won't add any extra noise audible from outside the case , ence i'm looking for a good soundproof case that will fit the nh d15. But i'm having a little trouble getting proper info on clearance for different cases . I will use a standard single dual channel kit of corsair lpx ram , and i'm planning to mount the second fan on the cpu cooler , and if my calculation aren't wrong ( specially IF the manifactures spec sizes aren't wrong ) i need an height clearance of 186mm , but i'n not sure about width clearance which should be 161mm from noctua spec , related to the rear case fan , which i obviously don't want to remove .
So here is the question , which is a good soundproof case that will fit my needs ? I'm planning to stay into the 150€ range , if possible even lower , around 120ish whould be optimal ( i'm also trying to save as much penny as possible , but i won't compromise on a cooler that it's  almost as silent  , it need to silent ) . My choise is pending on the phantek enthoo pro , or the corsair carbide 750 , more toward the first . But i'm really open to suggestion here . I don't care about the aesthetics of the case even less about side glasses windows , led stripes or such , but it need to be proper soundproofed , whit air filters , and no random "hole" on the case to make it look better , that screw the whole purpose of the "soundprrofing" and "filtering" like for the fractal design r5 . Also the smaller the better .
Thanks in advance to whoever will take time to read all this , and maybe also answer :)
https://linustechtips.com/topic/809688-proper-case-for-nh-d15/
Have you checked out Be Quiet's cases? They look really nice, and are designed to be quiet (thus the name).
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/809688-proper-case-for-nh-d15/#findComment-10166054
Yes , the only be quiet! case that may fit the nh d15 is the 900 pro which have a 185 mm of clearance for cpu cooler , you need to raise the little air window on the side pannel to fit the nh d15 in dual fan canfiguration , which i dislike . Also it's out of my budget .
https://linustechtips.com/topic/809688-proper-case-for-nh-d15/#findComment-10166110
dude an i7 7700 (non k) outperforms a 7600k at 5ghz
Unlocked i5's are a  huge waste of money, especially with ryzen 5 existing.  You could get a 6 core 12 thread CPU that OC's for less than the 7600k
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/809688-proper-case-for-nh-d15/#findComment-10166122
Thanks for the advice i'll think about it .
Put aside whatever cpu i my be building around , any thoughts on my topic question ?
https://linustechtips.com/topic/809688-proper-case-for-nh-d15/#findComment-10166421
That cooler is only 165mm..... There's a lot of cases that could fit that. Fractal Design Define series cases (Define S, Define C, R5) are good cases with sound dampening foam in them
https://linustechtips.com/topic/809688-proper-case-for-nh-d15/#findComment-10167436
If you wanna use a dual channel ram kit you need to move up the second fan a bit , since it cover till the 3rd slot , assuming you're using a low profile kit like the vengange lpx ( which i choose not cause they're mainstream and usually cheeper , but also one of the lowest profile on the market that mount a dissipator still ) you need to add extra height clearance ; nd h15 plus that said vengange lpx ram is up to 185.5mm in height that i rounded to 186 in my first post .
Also none of the case you mentioned fall under the "good case" category in my opinion , the Fractal R5 have some hole on the front corner that are not covered by the dust filters or even lees by any sound dampening mateial , rendering the whole idea of the soundproof case useless and also  the case will be filled whit dust after few weeks . I use to have one , so sadly i'm pretty sure what i'm talking aobut .
https://linustechtips.com/topic/809688-proper-case-for-nh-d15/#findComment-10167917
