Help with thermal pads placement on MSI 1080TI GAMING X
Solved by For Science!,
Definitely follow the instruction, the blocks are designed with the pads in mind, so if you have a pad where it isn't supposed to be, there will not be adequeate contact and you will suffer temps. A recent member on the forum did something like this and his temps were +30 C of what it was supposed to be.
Follow the instructions.
Featured Topics
BTSHalfLifeAndGmodFan2003 ·
Posted in Storage Devices5 -
2
Abaris ·
Posted in Troubleshooting3 -
2
6
2
SpookyCitrus ·
1
Hey_AND1 ·
Posted in Peripherals2
