Keep my 1070 or rx 580
MYX
I bought a gtx 1070 armor 4 days ago when there were no rx 580s in stock. Today I found a rx 580 strix at memory express and sort of panic bought it. I'm on a tight budget and returning the 1070 would put me back on budget, but is it worth it? I also have a crossfire compatable mobo and a psu that can handle CF, what's your guys' opionion?
Sell/return the 580. A 1070 is way better.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
I should mention the 1070 was 600$ before tax and the 580 was 410$
if you need money to survive and wont be able to afford your next rent payment then return the 1070, if money is just a little issue and you just wont have moeny for the week but can still pay your bills then keep the 1070,
the 1070 is better than the 580, so its all on you
Smoking weed at the red light like its legal
Are you sure? Should I return my psu too? What are your reasons behind it, I'm on a budget
Most PSUs support Crossfire. It's just a matter of having enough PCIe connectors and wattage. And I think you should return the 580 and keep the 1070, since it's much more powerful. 580s are built for 1080p gaming AFAIK, and the 1070 is for 1440p. Though you could keep the 580 and then upgrade to a better card when prices stabilize.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
Single card over dual?
Single cards are usually supported in more games. If the games you play can use Crossfire though, then keep the 580.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
Sell the rx 580 to a desperate crypto miner and get that sweet green. And keep the 1070 that is better in every way for gaming.
1070 will be better in the future than the Rx480. The 2gb more vram doesn't make it "more future proof" because the gtx 1070 is just a better card
