PCPartPicker part list: https://pcpartpicker.com/list/3XxhXH
Price breakdown by merchant: https://pcpartpicker.com/list/3XxhXH/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.99 @ SuperBiiz)
Motherboard: Gigabyte - GA-AB350-GAMING 3 ATX AM4 Motherboard  ($81.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($135.88 @ OutletPC)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($82.44 @ Amazon)
Storage: Seagate - BarraCuda 500GB 2.5" 5400RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: PNY - Quadro 4000 2GB Video Card  ($193.44 @ Amazon)
Case: Fractal Design - Focus G (White) ATX Mid Tower Case  ($54.99 @ SuperBiiz)
Power Supply: EVGA - 500W 80+ Certified ATX Power Supply  ($35.54 @ Amazon)
Total: $824.25
Generated by PCPartPicker 2017-07-05 15:08 EDT-0400
lttstore.com
https://linustechtips.com/topic/803186-bitwit-ryzen-workstation-build/
2 minutes ago, Being Delirious said:
Power Supply: EVGA - 500W 80+ Certified ATX Power Supply  ($35.54 @ Amazon)?
why?
why?
why? a used gtx 970 or 1050ti would be better
Depending on the application, some programs work best with Quadro/Firepro cards. Not all, but a lot do (Solidworks for example seems to work better from the benchmarks I've seen)
not exactly, SolidWorks hides some functions for Quadro and FirePro cards, for most people a gtx 1050ti or gtx 970 will be more than enough.
Workstation builds are not for most people
26 minutes ago, Lurick said:
It's a WORKSTATION build for CAD rendering and NOT some gaming machine
I'd disagree , this build could be used as a workstation but I only see regular desktop parts here.
The heck kind of workstations doesn't use faster dual xeons and instead opts for a more expensive slower ryzen platform? There are workstations from 2009 that are faster than this build. The memory isn't even ecc.
He mentions it in the video, that it's a workstation build, for his uncle who runs a small shop. This isn't supposed to be a gaming rig and it's not supposed to be top of the line or the fastest thing ever. It's for CAD drawing/rendering and machining parts and it's to replace a very very old and out dated machine.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
Sure sounded like a combination of owners budget and some parts he had on hand. The mobo he had which in turn determined the processor which in turn determine the ram, and so on and so on.
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
And what parts would you call "workstation" parts?
Also, i'm failing to see your point on the dual xeons here, at least with the same budget.
use 2011 xeons not 1366 xeons. and use the builds budget not just trying to replace the one cpu with many using a single cpu budget. theres 824$ there it can be distributed better.
well surely then we could spend 800$ on a pentium 4 machine that would better fit the "large price slow performance" model better than the current build.  Or we could actually try and make the fastest machine that will fit in 800$
Or we could use parts already on hand and a more limited budget and build an $800 machine for less for family. I also fail to see your point of how a Ryzen 1600 is a slow performance build.
Prior Build Log/PC:
what are you talking about? the build shown is 824$ with all the parts he listed , I don't see any free or reused parts in the list at all.
I see where the disconnect is. BitWit is a YouTube channel who posted this build. I still have no idea why OP posted it here since there was no mention of "Optimize it for me" or "How can I make this better". Just posted the title of the video and the channel name.
Prior Build Log/PC:
Then you clearly missed the part where @ 2:10 he said he had the mobo and acknowledged it was not a workstation board?
1 hour ago, Being Delirious said:
Professor, it's not my build.
If it's not your build , it's not the correct price , and you don't want people suggesting changes or questioning the selected parts.....
then why does this post exist?
*sigh* you should know this, I wanted a idea of want people thought. Not a guy questioning me so much.
lttstore.com
*CAD Tech Opinion*
I personally think it's a good build, especially for $800 for a small shop with probably only one or two users. Even considering it's only got 500GB of storage and doesnt have a great power supply. Even though the ram isnt "Ryzen compatible" I doubt he will have it OC'd hard, or at all, so it's fine. It's not like theyre going to be storing terabytes of information on there (my fairly extensive Inventor library is probably only 30GB *EDIT, added an extra 0 by mistake* ) and the GPU and CPU wont stress out the PSU too hard (Though for $5 we might have been able to squeeze in something a bit more quality like a 450 B3)
I'm running on a Xeon E3-1607 V0 workstation from 2011, I'd be ecstatic for this PC
9 minutes ago, TVwazhere said:
*CAD Tech Opinion*
I personally think it's a good build, especially for $800 for a small shop with probably only one or two users. Even considering it's only got 500GB of storage and doesnt have a great power supply. Even though the ram isnt "Ryzen compatible" I doubt he will have it OC'd hard, or at all, so it's fine. It's not like theyre going to be storing terabytes of information on there (my fairly extensive Inventor library is probably only 300GB) and the GPU and CPU wont stress out the PSU too hard (Though for $5 we might have been able to squeeze in something a bit more quality like a 450 B3)
For the Pure CAD loadout would you rather a 240GB SSD and have a smaller library ? like with your programs would you see the benefits of SSD ? or 7200rpm enough
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
For the most part having your program on an SSD vs a hard drive wont make a difference in hoe fast the program runs. It does help a little bit with how fast it loads, but it's pretty minor (I've had Autodesk Inventor installed on both an SSD and HDD at work and not much changed)
