God I have the worst luck.  My brand new to me 1070 seahawk is finally with me and a capaciter has fallen off...  after very carefully removing the waterblock it just fell off.  Not sure what it is for but meesa worried big time.
It SEEMS to be off on the corner of the PCB doing nothing but fan control but I'm a noob when it comes to chokes, capaciters and PCB in general.  It appears to still be in perfect condition as well.
@Droidbot @CUDA_Cores @iamdarkyoshi
Lol thanks in advance.
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/801520-help-a-capaciter-broke-off/
I would just contact MSI unless you're confident in your soldering skills.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Whoops... RMA it and said it came that way :)
Just now, CadetSparklez said:
Im no expert but it looks like u can easily solder it on
Leads are broke off that'd be difficult.
since most cards are surface mount imma go and say rip. but if you get a pro to do it. MAYBE it could be saved
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
you realize that you would have had to break the warranty sticker to get the cooler off. unless you were one of those people who use a pair of pliers to get the screw off
I didn't use pliers but it still looks in good condition.
eh, you better hope they dont notice
Lame of you to suggest that. By a cheap soldering iron and some solder. Buy a replacement capacitor I am sure the value is on the one you removed. Soldering isn't too hard. Just practice a couple times before you attempt on the graphics card and don't mess up ;)
Again, total solder noob here but it seems the capaciter is fine.
1 minute ago, AustinJ said:
I am dumb. Those look like bga. Time for a heat gun or an oven. Set the capacitor on top in the correct orientation and heat er up.
Fak that is absolutely last resort right there.
I'm kinda pissed with MSI for having a warranty void sticker on a waterblock card >:(
Well I think you would have to heat up the balls some way to get the capacitor back on. Yeah the warranty void sticker is dumb. I don't think my evga cards have them at least my 780 doesn't.
Evga is great that way.  Well hope it doesn't come down to that agagahahaha
Well thanks for the input so far, really appreciate it.  If anyone can think of anything else please let me know, or maybe tag someone with experience. :( hope I didn't just blow 400 bucks
@Damascus
Buy a chisel tip soldering iron (look for the yihua ones and just buy a 20¢ chisel tip)
Get some flux
Flux each side of the cap and PCB pads
 Just touch the soldering iron on each side until the solder melts, add a bit more solder to each side
The solder should flow onto each lead of the cap and pad, making an electrical connection
Done
Alternatively you could send it to me for the price of return shipping, and I'll fix it free if you aren't comfortable doing it yourself
That would be a piece of cake to solder back into place, if you know what you're doing, and have the tools. If you don't, make sure you either learn how to solder properly first, or take it to an electronics repair centre. It would probably take a repair centre less than 1 minute to solder that back into place, but be aware that some repair centres charge a minimum service fee, which could be like $40. Ask on the phone beforehand to see what a store's policy is - and ask if they can make an exception for your single capacitor that needs to be soldered if they want a crazy amount for the job.
Also, don't poke around on the board if you don't have to, and discharge electricity from your body by touching some larger and grounded metal surface, like maybe your PC case, for a few seconds. The static from your body can cause damage to sensitive electronic components. I have both temporarily damaged, and permanently damaged some expensive equipment I was working on before, due to static damage.
I wouldn't do the oven thing, as chemicals from the board's electrical components can release into the oven, which will then get into food that's next cooked in there.
You own the software that you purchase - Understanding software licenses and EULAs
"We’ll know our disinformation program is complete when everything the american public believes is false" - William Casey, CIA Director 1981-1987
Wow, thanks for the awesome step by step instructions. I already have an iron, I would just need the tip.
Now I would love to send it to you but I think it would cost waaay too much as the msrp on the damn thing is like 600 USD or something like that and shipping it will likely cost more then 100 bucks (especially from up here in the frozen north, eh?)
No problem! Flux is your friend
Yeah I wouldn't recommend it either. But if someone was desperate enough it *might* work.
Yeah, where do you suggest I nab my Flux/solder from?  There is a local store that sells Arduino parts and circuit boards etc. so I'm pretty sure they have solder.  What is a good price?
