Will a hyper 212 evo fit?
Leo_Dahlin
I want to buy a Hyper 212 evo for my second PC and was wondering if it will fit.
https://pcpartpicker.com/list/XbCqf8 Pcpartpicker says it will fit but i'm not sure because i have seen many people saying that it won't with high profile RAM.
Pictures of the PC: http://imgur.com/a/HmdI9
Main: Gigabyte G1 980Ti, i5 6600k, MSI Z170A M5, 16GB DDR4 2666, NZXT H440, NZXT x61, EVGA 750W G2, Windows 10
Second PC: EVGA Reference GTX 680, i7 2700k, 16GB DDR3, Corsair 300R, Corsair CX500W, Windows 10
Laptop: Acer Aspire 5750G, GT540M, i7 2630QM, 6GB DDR3, Windows 7
It might hit the RAM, but even then you can just put the fan on the back of the heatsink so its pulling air through rather than pushing, and it should fit fine.
PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD   PSU Corsair CX750M - Cooling Stock - Case White NZXT S340
Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL  Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter
It will hit the RAM. That's a high profile RAM, but you can put the fan on the back of heatsink
You can see in Anandtech's review of the case that their Hyper 212 EVO hung over the first DIMM slot (granted it's obviously a different board), which I assume is why they moved over to the next two slots instead. The RAM they used is lower profile than yours, so I'd wager in the same "push" configuration, it probably wouldn't clear the RAM's heatspreader.
You can also move the fan higher up the cooler and have it sit just above the ram, but this may increase the hight if it comes above the heat pipes.
H7 would be better pick here. It will fit the case, doesn't interfere with RAM and is otherwise at par or better than 212.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
