Akasa Vegas RGB Fan <fast response welcomed>
Solved by W-L,
1 minute ago, dave_k said:U think i should get the Akasa or save some ca$h for the MasterFan ?
Both are alright as a fan but not spectacular in terms of performance. They are a airflow optized fan, but as for which one to get that is really up to you, I think the masterpro should be a little better.
I have seen seen some other odd ball fans out there that seem to be decent that use the RGB header system but they may be hard to obtain.
