Ethernet cable only working at 10Mbps :(
Go to solution Solved by lukesterboy,
All fixed, just put new ends on the cable, as i expected.
My ethernet is only working at 10 Mbps now. It always used to work at 1 Gbps. Yes i need 1Gbps because i have a 200Mbps internet connection. Nothing has changed.
Either the device at the other end is 10mbps or the cable is bad.
if you want to annoy me, then join my teamspeak server ts.benja.cc
6 minutes ago, Electronics Wizardy said:
try a new cable.
Network diagram?
It's a custom cable that i made. What im thinking it might be is maybe the cable has been pulled and one of strands of cables have been pulled out.
Network diagram?
PS on my router page it shows as 1Gbps.
Bad cable.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
Just now, Jrock said:
Bad cable.
Ok, for sure? I could try unplugging my computer and taking it to the router but that is a lot of hassle.
I would say there are at least 2 or 3 pairs of wires that are bad for it to negotiate to only 10Mbps. Definitely a cable though if you've moved it recently and given it a good tug by accident.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
I mean you can purchase a network card to test if its your MOBO, but a cable is WAY more likely in this situation.
welcome to the world of IP hardware troubleshooting, where everything is a hassle.
if you've got a laptop or something, try plugging into the cable at the computer side, see if it's adapter related.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Yeh.
I'm not going to purchase a network card, i don't think it is the mobo the computer hasn't been moved or touched or anything. As i said it worked perfectly fine before 1 Gbps.
Haha. I haven't got any other device i can test it with actually. I'm just going to try changing the end of the cable now, i'll get back to you guys and see if its made any difference.
Move the pc to the router and use a short 5ft cable that you got with it.
See what happens there.
I could do, just means i've got to take a monitor keyboard and mouse, power adapter, etc.
If i do re-wire the cable what wiring diagram should i use, is this ok?
Move the router? You dont need an internet connection for it to negotiate the speed.
I can't it comes in at a fixed point. On the coax cable.
doesn't matter. you don't need the coax connected to negotiate a network. It's just a box. you don't need internet to do it.
System specs:
Ohh i see what you are saying, let me try that...
