Hey!
I wonder if someone has a good lifehack or trick or some good tips for making my pc more dust resistant.
Are there good working ways to collect less more dust even with dustfilter on?
And how often do you guys a clean up for your PC? once a week? every second week?
I clean my PC once a month but i think that's not enough.
https://linustechtips.com/topic/794343-dust-problems-with-the-define-c/
Have a Positive airflow in your case and have the intakes covered with dust filters. I don't clean my PC too often like every 2 months if I even care.
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
I use a HEPA air filter connected directly to my PC for 99.97% dust-free air.
If you have pets or carpet then you probably have a ton of dust in your room.
Maybe try better fan filters or get a room air filter? Because you're breathing all that stuff in too, you know...
Yeah 2 dogs and my room is full of dust after a week. If i go 1 meter over my table with my finger my finger is gray without a single colored mark.
Air filter is a good idea but i will move in one or two years anyway. Are there more good aftermarked filters to buy like the HEPA Filter?
- Keep your PC off the floor (especially if you are on a carpet), even just sticking a few textbooks underneath it can make a difference
- Maintain more intake airflow than exhaust (positive pressure) with the minimum total flow requires for the cooling.
- Use the dust filters that came with the case
  • 2 weeks later...
I use the dust filters that comes with my Define C. I've never got the idea to buy extra filter stuff. But putting more filter on top of the installed filters seems like a good idea for me.
I guess youbcan also consider minimising the fan speeds. less airflow into the case = less dust.
What are your specs?
ASUS Prime Z270-A , i7 7700, Cooler Master Hyper 212X CPU cooler, 2x8gb HyperX Fury 2400mhz RAM,
1x Corsair HD120 RGB Fan in the back of the Case and 2x Fractal Design fans on the front that came with the Case,
Palit GTX 1070 Super Jetstream.
My specs should be listed on my profile but i don't know how private i made my profile on the LTT Forum (if that's even possible).
There is one other thing i haven't tried yet... or that i going to try now. I removed the dust filter on the top and replaced it with the solid panel so no air goes out through the top.
Im kinda nervous about that because my old pc is running at 80°C+ without airflow or a open top.
What rpm are you running the fans at and what direction are they facing?
If you have all your intakes filtered and your exhausts don't overpower your intakes, dust should be minimal.
If you're worried about your temps, use a program like OCCT and Unigine Valley to stress your components and see what your load temps are.
  • 4 weeks later...
All Fans pushing air to the back of my Case. I don't have any Fans on the top of the Case and it seems like the dust is coming from the top. It was better with the closed top but it is still bad in the end. The front Fans are pretty slow. They are the Fans that comes with the Case. In the back i got a HD120 from corsair. I'll switch the front Fans soon to the Corsair ML140's.
Dust pretty much always comes from top, like snow... Unless you have a really dusty air, or you keep your pc on the floor.
I took a look at my psu dust filter, which is located under the case. It looked like new without being cleaned for 4 years. I took it completely away after I tested how much it restricts airflow just by blowing through it.
CPU: Intel i7 3970X @ 4.7 GHz  (custom loop)   RAM: Kingston 1866 MHz 32GB DDR3   GPU(s): 2x Gigabyte R9 290OC (custom loop)   Motherboard: Asus P9X79
Case: Fractal Design R3    Cooling loop:  360 mm + 480 mm + 1080 mm,  tripple 5D Vario pump   Storage: 500 GB + 240 GB + 120 GB SSD,  Seagate 4 TB HDD
PSU: Corsair AX860i   Display(s): Asus PB278Q,  Asus VE247H   Input: QPad 5K,  Logitech G710+    Sound: uDAC3 + Philips Fidelio x2
HWBot: http://hwbot.org/user/tame/
Best Practices:
1. Always have dust filters on all intakes.
2. keep positive pressure (more fans intake than exhaust), keep in mind filters reduce airflow so 2 filtered intakes =/= 2 exhaust, also consider different fans perform differently.
3. Keep PC off the floor and as high as possible. The higher up the PC is, the less dust it gets exposed to.
4. Keep your room clean, vacuum and dust often.
5. With cases with an open top and without exhaust fans on the top, install dust filters on any vents facing up, this will keep dust from "snowing down" into the case.
6. If the stock filters are large pores then get replacement filters with much finer mesh to catch finer dust.
My case is well setup to the point that I maybe have to dust every 6mo and even then it's almost nothing that's gotten inside. It sits on a desk so very little dust exposure as well.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
