This is my first attempt at soldering anything.
I need to solder three 16AWG wiring together (Which will be used for Sata Power & Molex).
1. I was just wondering what the best method would be for setting up the wiring. This is what I came up on my own. Not sure if this is good enough to use or if it's wrong.
2. I haven't gotten to soldering bit, I was wondering how much soldering is enough? I assume I should encase the wires I'm soldering together.
My Setup:
I have one wire going from PSU to First hard drive & the second two wires I have wrapped around the first wire which will then run to the second & third hard drive.
The Soldering Irons I have:
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
https://linustechtips.com/topic/792453-quick-help-with-some-soldering/
My Setup:
That's not a problem twisting like that give it more mechanical strength but just be aware when twisting it's good practice to try and keep the cross sectional area the wire as close to as original as possible to not change the dimension of it.
Can't really see how well the solder has flowed in from the photos but as long as you can still see the strands of wire with solder flowed in your good.
[IMG]
For thicker gauge wire, this method works rather nicely:
However I would avoid joining 2 wires altogether if possible.
Cheers!
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
here are some tricks i can think of off the top of my head:
1. dont get too fussy on the way you twist the wire you just want the twist to produce a join small enough you fit your insulation over. for thin wires where it is difficult to do what is shown above, I just twist them together and fold it back.
2. heatshirnk costs money and you dont need to spend money on heatshrink. I often recycle insulation from offcuts. If your calble is short enough you can just slide the insulation down over the join.
3. crimping is a lot faster than soldering. For thick cables we always crimp as the joins is smaller and cleaner. Twisting thick wires is not practical
ψ ︿_____︿_ψ_
Looks fine.
Heatshrink is almost free... You can buy 1000 precut pieces for $5. Well-worth the money imo.
2. I have allot of heatshrink. That is not an issue.
3. It also means I would have to daisy chain them. Which is a pain to do specially with Sata Power since the wings on the terminals are not large enough to fit two wires. (I'm not going to use T-punch connectors).
I think you mean stagger, as in cut the wires at different lengths? I dont see how that is an issue. I never said to use automotive style crimps
ψ ︿_____︿_ψ_
Nope. I mean Daisy Chain. Who said anything about automotive crimps? I'm using official Sata terminal made by Molex.
[IMG]
That's going be the difficult part for me, Atlease until I get soldering down.
Shame PSU don't give you more Sata ports. I have plenty of VGA slots, only five for sata & molex.
yea we are def using different words for the same thing and the same words for different things.
ψ ︿_____︿_ψ_
It's wire going from one connector to another to another.
T1mt2zXbxfXXc2b4c._112417__44700_zoom.jp
Like I said previously the main issue is getting two wires inside one sata terminal. It's why I went with soldering method.
I could also add a second PSU, not sure I want go down that road just yet.
[IMG]
Here is a cleaner photo of my setup.
Cheers!
I wish that was an option. I only have five slots for Sata & Molex.
Harddrives that require Sata Power - 9 | 11
Devices that require Molex Power - 7
As you can see that is not an option.
That's alright I would try to taper it a little so to not have a ball or bulged once heatshrinked, you can if you want split the main wire and have the two extra connections twist through the center. Lutro shows that method really well here if you haven't seen 14:00
Using that Method This is what I came up with.
You an buy adapters for this purpose.
ψ ︿_____︿_ψ_
If your talking about PSU, I'm aware. Like I said I'm not sure I want to go down that road just yet.
Going to do some quick soldering test, If I'm not happy with the results I might looking into adding another PSU. I do have a spare 850 P2 PSU sitting around.
