I need advice on Ryzen 1700 temperatures
Solved by Damascus,
Considering what is likely a full copper loop in push/pull (assumin Vardar or similar fans) with good fluid your CPU is probably accurate, you actually have enough cooling headroom to add a GPU to the loop
Featured Topics
AlyShazli ·
4
Emmanuel Katto ·
Posted in Peripherals3 -
1
2
Rusty Proto ·
4
WildOne ·
Posted in New Builds and Planning1 -
solarbear ·
Posted in Troubleshooting1 -
5
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
