Thermal pads
Solved by Mick Naughty,
The rest you will have to cut and replicate. Still the same thickness.
Isnt gonna be a site that lists the info as they are all the same for the vram then most are the same for the vrms and chokes. Not worth it to compile that info.
Featured Topics
LLENNxP90 ·
Gat Pelsinger ·
Posted in Laptops and Pre-Built Systems1 -
Mumintroll ·
Posted in Windows3 -
mr.happy ·
Posted in Power Supplies6 -
5
300DaysToGTA6 ·
Posted in Storage Devices5 -
5
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
