HELP I DONT KNOW WHAT TO DO
Solved by Jurrunio,
52 minutes ago, DeluxeClaus said:Now I'm here how to get out
That's the BIOS screen. Very useful, but you need an OS before anything.
To install Windows or Linux, you dont necessarily need an optical drive because even an USB with Windows 10 can install an OS for you. The first thing though is to get Windows 10 into a 4GB or more USB. It takes from 30mins to multiple hours, depending on your network speed, so you will need to use your own computer (laptop, PC doesn't matter) or ask your friend to help you.
After you get it into a USB, insert into your PC, get into BIOS, make it boot with USB, then just wait.
