Can you tell me good method to compare cpu?eg
xeon e5 2690 v2 vs ryzen 1700x
i have to decide soon
deal is ending soon both for same price.
any software ?
does cinebench results depend on gpu in render test.?
The argument for ryzen over i7 is games will support more threads in future .Now overall which cpu have more power considering all threads fully used?No intention of overclocking(minute may be exception)
https://linustechtips.com/topic/777520-urgent-help/
https://linustechtips.com/topic/777520-urgent-help/#findComment-9806491
Just now, nerdslayer1 said:
i would get this because
- newer
- better IPC
- better performance
- cheaper to setup and maintain
- more performance
any software ?
ryzen will be better aswell as cheaper mobos with it
CPU: Intel I5 4690K | GPU: Asus R9 280x | PSU: Evga 600w | RAM:8GB DDR3 | HDD: WD 1TB | HDD: WD 500GB | SSD: Sandisk 120GB
https://linustechtips.com/topic/777520-urgent-help/#findComment-9806513
how can i get numbers pls me not too smart
I googled Cinebench scores for each.
e5 2690 v2 got 1414 (2 cpus got 2827)
R7 1700x got 1527
https://us.rebusfarm.net/en/tempbench?view=benchmark
http://www.guru3d.com/articles-pages/amd-ryzen-7-1700x-review,10.html
Cinebench is a good representative of CPU performance in multi threaded workloads.
if you want to annoy me, then join my teamspeak server ts.benja.cc
https://linustechtips.com/topic/777520-urgent-help/#findComment-9806583
http://cpu.userbenchmark.com/Compare/Intel-Xeon-E5-2690-v2-vs-AMD-Ryzen-7-1700X/m13436vs3915
Ryzen seems to be around 30% better than Intel in this scenario.
In cinebench, Ryzen is again better.
But what will you be using it for?
If it's going to be some kind of server, I would probbably go with Intel, since it's still a bit more stable, and having more cores will allow you to have more hyper-v machines. If you are doing that ofc.
But then again, you would be investing in dead platform, while Ryzen is new, and there are new CPUs comming out in next 3-5 years, that will work on same socket as now. Those will be called Ryzen+. So aftter 3 - 7 years you will be able to upgrade your CPU.
But then again you could also upgrade to i7 6950X on that 2011 platform if you wanted to.
I'm not getting anywhere ... can't decide.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/777520-urgent-help/#findComment-9806762
i use for gaming for 5 7 years..People say games will start using more threads which i think will happen.So over all which device have more Total power as passmark and cinebench tells opposite story.
https://linustechtips.com/topic/777520-urgent-help/#findComment-9808793
R7 1700x got 1527
pass mark and cinebech telling opposite story how to decide
https://linustechtips.com/topic/777520-urgent-help/#findComment-9808794
For gaming ... go with Ryzen for sure.
WD My Cloud 4TB
https://linustechtips.com/topic/777520-urgent-help/#findComment-9809255
6 minutes ago, sarggames said:
explain please.If games start using more threads then in that situation which is better.
I am not talking about current games.
Both CPUs have 8 cores/16 threads, so the number of threads the game is 'using' is not a useful point of comparison.
That Xeon is 5 years old. It has Sandy Bridge's IPC, and a lower clock speed on top of that. Ryzen 7 is clearly going to be faster in virtually any task. If both are the same price, you're either getting a terrible deal on the Xeon CPU or an amazing deal on the Ryzen CPU.
https://linustechtips.com/topic/777520-urgent-help/#findComment-9810474
Just now, typographie said:
Both CPUs have 8 cores/16 threads, so the number of threads the game is 'using' is not relevant.
That Xeon is 5 years old. It has IPC comparable to Sandy Bridge, and a lower clock speed on top of that. Ryzen 7 is clearly going to be faster in virtually any task. If both are the same price, you're either getting a terrible deal on the Xeon CPU or an amazing deal on the Ryzen CPU.
xeon have 10 cores that is why i am confused
https://linustechtips.com/topic/777520-urgent-help/#findComment-9810480
No, the number of cores it has depends on the model of Xeon. There are quad-core Xeons, and there are 14-core Xeons (I think).
http://ark.intel.com/products/64596/Intel-Xeon-Processor-E5-2690-20M-Cache-2_90-GHz-8_00-GTs-Intel-QPI
I'm not seeing things, this model has eight Hyperthreaded cores, yes?
https://linustechtips.com/topic/777520-urgent-help/#findComment-9810493
No, the number of cores it has depends on the model.
I'm not seeing things, this says it has eight Hyperthreaded cores, yes?
v2 model
https://linustechtips.com/topic/777520-urgent-help/#findComment-9810496
