6 minutes ago, Mattlinic said:
has anyone had issues with cable mod? it appears the messed up on some cables i ordered and its been a month since i contacted them with no reply.. the connector pin location isnt the same for the cable i ordered5911452b11f7e_Photo2017-04-2773930PM.thumb.jpg.1b986939092dd9e63a289e1edb6c6147.jpg
Hi @Mattlinic, please email support@CableMod.com and we can help figure out what is going on.
https://linustechtips.com/topic/777305-cable-mod-screw-up/#findComment-9803871
18 minutes ago, Mattlinic said:
snip
What makes you guys think there is anything wrong with these cables? From my understanding its normal for 1 of the 24 pins in a 24pin atx connector to be missing, unless you're talking about some other issue?
https://linustechtips.com/topic/777305-cable-mod-screw-up/#findComment-9803908
Just now, Zyndo said:
What makes you guys think there is anything wrong with these cables? its normal for 1 of the 24 pins in a 24pin atx connector to be missing:
Isn't it the jumper or something?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/777305-cable-mod-screw-up/#findComment-9803914
@Zyndo there may not be, but just for verification purposes we of course want to check so that there are no worries. :)
https://linustechtips.com/topic/777305-cable-mod-screw-up/#findComment-9803918
I have no idea. I'm not entirely familiar with PSU's and their pinouts. I do know that on every 24pin ATX connector i've ever seen, they all have one missed pin... some copmanies will run an unconnected dummy cable or fill it with dummy pins for posterity sake or aesthetics, but one a 24pin ATX cable only uses 23 actual pins so far as I know. You can check this by going to google and typing in 24 pin atx cable and you will see MOST of the images have a pin/wire missing (and the ones that don't are likely just using a dummy pin as mentioned above)
https://linustechtips.com/topic/777305-cable-mod-screw-up/#findComment-9803928
10 minutes ago, Zyndo said:
I mean before he cries foul, buddy should just plug it in and see if it works first lol.
And risk killing his entire PC?
Better to ask first and test later IMO.
https://linustechtips.com/topic/777305-cable-mod-screw-up/#findComment-9803969
the problem is that the "hook" is on the wrong side of the connector
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
https://linustechtips.com/topic/777305-cable-mod-screw-up/#findComment-9804015
what do you mean by that? the hook is going to be where the hook always is. the plastic housing for the pins has only one layout so far as I'm aware. if it wasn't, it would defeat the entire purpose of it being a standard.
https://linustechtips.com/topic/777305-cable-mod-screw-up/#findComment-9804028
ow, my bad. i just saw I looked wrong. i thought the last row of the upper plug was the first row of the bottom one. sorry for the inconvinience.
https://linustechtips.com/topic/777305-cable-mod-screw-up/#findComment-9804039
I can tell from experience with CableMod they usually use older versions of pin layout (Like EVGA, they don't use the revision layout). Not sure what Kit you bought. Most 24 Pin ATX should only be missing one terminal not two.
Here is comparison between CableMod 24 Pin ATX & cable you get with EVGA 1600W T2 PSU.
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
https://linustechtips.com/topic/777305-cable-mod-screw-up/#findComment-9821921
