Hi All,
Has anyone had any experience with setting up a UPS system? Just need some help/information
Cheers
Barry
Gaming Rig:
CPU: AMD Ryzen 3600X @ 4.1GHz All Cores - Ram: 16GB Corsair VENGEANCE - GPU: 5600XT MSI Gaming X - Storage: Samsung EVO 840 250GB - 2TB Seagate Drive OS: Win10
HTPC Rig:
CPU: i5 6400 - Ram: 16GB - GPU: 970 GTX - Storage: 120 Kingston SSD & 2x 1TB Seagate Drive OS: Win10
https://linustechtips.com/topic/775334-question-regards-to-ups-system/
Awesome!
Ok I've been tasked with possibly getting UPS systems into our sites. What I'm looking to keep powered is the following:
  • Broadband router
  • Phone System
Simple but only things really that are important to the site, Now what I'm not sure on is how big of a UPS system i would need to keep someone like the above on for lets say 1 hour?
Gaming Rig:
HTPC Rig:
8 minutes ago, DarkShadowUK said:
Awesome!
  • Broadband router
  • Phone System
go buy your self a Kill A Watt Electricity Usage Monitor and figure out you max draw . if your only using 100 watts then a 1000w ups should be overkill for you needs
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
1 hour ago, DarkShadowUK said:
Awesome!
  • Broadband router
  • Phone System
As said you will need to determine the power usage of those devices, but those being fairly low power draw you can upsize the UPS to gain a bit more runtime during an extended power outage. What are the devices that are exactly going to require a UPS?
