is 24/7 Liquid Cooling safe?
Solved by JakeNTech,
If you are using a AIO then you should not have any issues, just as long you occasionally look at the temps it should be fine. The only real damage that may happen when you use an AIO is the water evaporating from the system, thats why you need to monitor temps. If you are unsure stick with air cooling, It's less likely to go wrong and when it does it is likely the fan has died, but I have on that has been used every day since 2003 and it still works fine. If it was me in your position I would sick with air.
