Using twice the hard drive space than I'm using
Solved by Electronics Wizardy,
Just now, amftech512 said:Is there special software that is required to format a drive using ReFS? Should I get a bootable Linux drive and use GParted? Or does it not make a difference to just use NTFS?
what OS's
REFS is windows only
if you want windows + linux + osx use ntfs
If you want to use less space use compression on ntfs. It will also make it faster.
Featured Topics
pchelp ·
pontikos ·
Posted in Troubleshooting2 -
3
wolfgangam ·
Posted in Windows3 -
9
3
2
