So i am new to electrical wiring and i need some help, so what i want is a wall switch to turn on multiple wall sockets instead of turning on the sockets individually. This is so i don't have to turn each plug on individually for my PC. Can you help me with this?
Thanks
Specs:
Motherboard: Gigabyte Z97X Gaming 3
CPU: Intel Core I7 4790K
GPU: Gigabyte G1 Gaming GTX 970
RAM: HyperX Fury 16GB
HDD: Seagate ST3000DM001 3TB
SSD: KINGSTON SV300S37A480G 450GB
Cooler: Corsair H100i GTX
Case: NZXT H440 Red
Monitor: DELL U2412M
Keyboard: Gigabyte Force K7
Mouse: Corsair Sabre RGB
https://linustechtips.com/topic/767423-power-sockets-controlled-by-one-switch/
5 minutes ago, Electronics Wizardy said:
Just run the power from the breaker to the switch to the outlets, just run the in parallel.
Do this.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
18 minutes ago, Electronics Wizardy said:
No reason to unplug your pc, just let it sleep
But you can wire this in your house very easily. Just run the power from the breaker to the switch to the outlets, just run the in parallel.
Wait it's that easy!
Specs:
Case: NZXT H440 Red
Careful with loads on the switch though
A switch meant for lighting should not be used.
Only a fused isolating switch meant for electric radiators and stuff.
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
1) why are you unplugging your PC? Just shut it down and leave it plugged in. There is no reason for power to be shut off.
2) If you plug everything into a power bar, then you can just use the switch on the power bar, or plug it into one socket that you control with a switch in your room if you already have that wired up
3) if you still need to wire all your plugs to one switch, then you need to pay an electrician to do it because you need to follow a bunch of regulations that are in place to prevent people like you from burning their house down by trying to do house wiring themselves.
