1200w for 1080ti 3 way sli
Go to solution Solved by DildorTheDecent,
1 minute ago, Enderman said:
99% of games do not support multi-GPU, so it is in fact no gain to add more cards.
Here's at least 500+ games with SLi support from Nvidia:
http://www.geforce.co.uk/games-applications/technology/sli?title=&sort_bef_combine=created DESC&sort_order=DESC&sort_by=created
I guess if you want to be autistically correct it could represent the 1%. But there are games out their that support it. As long as the games that OP plays support it then that's fine. It also isn't hard to use AFR 2.
I've had success in BF4, Fallout 4, Crysis 3, Titanfall, DOOM and few others for SLi support.
And SLi is also an enthusiast thing. Maybe OP finally wants to ascend.
1 minute ago, SirFlamenco said:
Yea I see, but even if it does use 1200 watts the Evga p2 can provide something like 200 watts over this.
Yup. PSUs have overdraw. My 850 G2 can overdraw to about 1200W from the wall. Maybe further but haven't tested.
Is an Evga 1200w p2 power supply gonna be enough to support 3 1080ti overclocked? The cpu will be overclocked and it's gonna be a 5960x and I might watercool it.
So true it hurts
Yes, however, outside of benchmarks and some specific applications, 3 way SLI is not supported. If you're gaming, 3 way SLI will not work, only 2 way.
Yeah, but why are you buying 3 1080tis if SLI only supports two?
You can get it to work trough nvidia inspector, but that is not my question.
So true it hurts
Old bridge + nvidia inspector profile gets 3 Way and 4 Way working again.
Nvidia have not totally disabled 3 Way and 4 Way.
Otherwise these benchmarks would't be a thing:
http://hwbot.org/submission/3495753_bossmac_3dmark___fire_strike_ultra_3x_geforce_gtx_1080_ti_16702_marks
http://hwbot.org/submission/3520881_h2o_vs_ln2_3dmark___fire_strike_ultra_4x_geforce_gtx_1080_ti_25063_marks
Nvidia haven't disabled it for benchmarks like 3DMark last I heard, so there'd be no reason to even use round about ways if you're benchmarking. (I haven't looked that up, at least not recently, so may be wrong there)
Given how Nvidia has pretty much disabled it for gaming (maybe you can still get it to work, but for how long?) I wouldn't consider it a good choice. OP can do what they want, but just trying to help.
Both @Enderman and I answered your question, just added an opinion/information at the end to try to help. 1200W is more than enough for 3 1080Tis.
Both @Enderman and I answered your question, just added an opinion at the end to try to help. 1200W is more than enough for 3 1080Tis.
 You can get it to work..
So true it hurts
A wee bit off topic why do you want 3 way sli? Any vids you can check out clearly show its a terrible idea with many games not even launching. I could understand 3 cards non sli'ed for things like rendering though.
Does it even scale though?  Even on the 900 series when tri/quad SLI was still supported, you got pretty much zero gains adding a third card and in some places the fourth card went backwards.
Also, yes, 1200W is beyond plenty.  You could probably fit it all in 850W.  Remember that your system is probably never going to be under full cpu + gpu load at the same time.
Workstation:  14700nonk || Asus Z790 ProArt Creator || MSI Gaming Trio 4090 Shunt || Crucial Pro Overclocking 32GB @ 5600 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 9900nonK || Gigabyte Z390 Master || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 3080Ti Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
And it's stupid and you shouldn't do it.
I want it in order to have better fps in games and have a bigger epeen in 3D mark.
First elaborated answer, than you. And I know the scaling is not very good but it's something I want to try.
He didn't take time to mod the drivers, as it is shown in the video I put.
So true it hurts
Yes, we've already established that, I didn't argue you couldn't after @DildorTheDecent explained it, just said I wouldn't recommend it. Scaling for 3+ SLI has always been bad. Now that it's not really supported (yes, you can still do it, but Nvidia doesn't really want you to), support from developers is going to be next to non-existent.
I would advise you save the money as you'd be dropping several hundred dollars for a small improvement in some games and just a small heater in others.
Yup, but it's surely gonna be one hell of a system.
So true it hurts
Just another example of someone with more money than sense -_-
Whatever, he can do it if he wants and just deal with the issues and stuttering and stuff.
Updated my post with a little explaination. Basically, more than 2 way SLI has always had issues. It tends to offer very little in the way of FPS improvement and can negatively affect frame times (those matter for the perceived "smoothness" of the game). That was back when 3 and 4 way SLI was supported by Nvidia. Now that they've basically pulled official support, developers aren't taking the time to optimise the game for over 2 way SLI. Even with just 2 cards, SLI support seems to be getting worse from what I've seen. I'm having more issues with SLI than ever with recent games.
Or just a proof that a 38k+ posts forum user can be wrong and get mad after this. No hate, but don't react like this.
So true it hurts
It does some scaling on certain drivers and games. It's not the 3x gain that you would expect to get though. But then again 2 cards isn't always a 2x gain, but it's damn close.
Three cards is 2.5x gain at best or in this case it's provably more like 2.25x at best or lower.
1200W does sound more than enough for three 1080Ti's though. would be quite close on a 850W though. I can do 550-600 full with two 980s and 5820K under load.
This build is more of a dream becoming reality. When I was younger, I used to admire so much these overkill systems but now I have the money to do one, the the roles are inverted.
 Outervision seem to estimate the overclocked system at around 1300w, is this even right?
So true it hurts
The ones that do will often get close to no performance increase from a third or fourth card.
What you do get is triple the power consumption, noise, and heat.
If OP's goal is just wasting as much money as possible then he should buy new titan XPs instead, those will actually give slightly more performance because of better specs per card.
PSU calculators are rubbish.
I can understand that. Aesthetics played a massive part in my build, as well as some epeen. If I had gone for pure performance it would have been much cheaper.
Still, I personally wouldn't be able to justify the price of a 1080Ti when it's not going to make much of a difference, but it's ultimately up to you.
Completely wrong, PSU calculators generally way overestimate the power draw. 1000W could run the system just fine, 1200W will do it easy.
Pretty much all the games support 3 and 4 way sli with Pascal, as long as you create custom profiles in Nvidia inspector.
So true it hurts
No, they actually don't, but you can find out for yourself.
