(Kinda big) issue with the cooling for my UX302LA.
Go to solution Solved by Mr.Meerkat,
@Thue500, @dizmo, @TheDankKoosh
If you guys care, I've fixed it!
65C max temp under 100% sustained load :D (it was going up to 95C yesterday while the 2 "mounts" were broken)
ALL HAIL OUR LORD, OUR SAVIOR, (two part) EPOXY!
But yeah, applying epoxy to em yesterday and leaving them to dry for 20 hours~ seems to have done the trick :)
Before:
After:
So basically I have recently just bought myself a second hand Asus UX302LA. It was running a bit loud (but temps were in check) so as an enthusiast, I decided to replace the TIM with MX4.
When I opened up my laptop to change the TIM, I noticed how 2 of the 4 mounts for the CPU contact plate has been sheered off the motherboard...
The bad thing is both mounts that have come off is on one side so it's actually affecting cooling. If I load up a youtube video, the difference between me forcing full contact and just allowing it to sit naturally is whether the fan is on or not (which is actually quite loud). It looks like it was soldered on so would it just be as easy as me adding some new solder to the two mounts/nuts?
Any ideas?
edit: Probably should say how it's actually not overheating without those 2 fasteners but it is louder without em...a lot louder :/
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
2 minutes ago, Thue500 said:
Can't help my not as loud as an Microsoft Surface Pro 3
With the paste changed anyway, it's actually running 10C cooler and slightly quieter but still, I'd like it actually running passively rather than always having the fan on :/
The guy/girl you bought it from doesn't he have the receipt? Or have you broken the warranty by opening it?
That no longer matters, it's out of warranty anyway :P
I've not broken any seals but I don't feel like asking for a refund as this is the second time I've opened it up already where its possible I may have done something wrong.
Give it a try, such a big company as Asus have fooled so many people (Have you see Linus newest video about Warranty) that if you can get a refund do it. (Not hating on Asus love the company)
1. I bought it second hand
2. Its warranty should have expired last year :P
Okay... bought something once second hand and under shipping, it broke but because I had the receipt I just got a new one through the company.
Sorry can't help :/ good luck tho
why'd you use mx4? IC or gelid would have done much better.
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
...that's a stupid question to ask...
Maybe it's the only thing I stock/have on hand? :D
True, but that mx4 will be dried up in 6 months with that heatsink design.
8086k Winner BABY!!
Main rig
GFs System
And I would have replaced it within the next month or so...once I find a fix to get the mounting nuts to go back into place xD
Before:
After:
