So apparently ASrock came out with a gpu that supports 6 gpus...
 http://www.pcgamer.com/2013/11/15/asrock-releases-motherboards-designed-to-mine-bitcoins-generate-internet-moolah/
so it is made to mine bitcoin but like with 6 gpus I'm guessing it means like having 6 computing cards?
Now I don't know much about mining bitcoin, but I know you can't put 6 gpus in SLI so can someone tell me wtf is this?
MSI Z87-GD65 - GTX 760 DirectCU II - i5 4670k @4.0GHz - 16GB Corsair Vengeance @1866 MHz
https://linustechtips.com/topic/76600-6-gpus-in-a-system/
you don't need them to work as one. they can individually do work to mine the bitcoins.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1051258
Ohh alright, that's what I though, but I saw this article on a thread on another forum from someone asking if 6way SLI is a thing so I was like wtf?
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1051262
Wha?
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1051267
6-way sli would be pointless unless devs caught on. You can throw up to 12 gpus in a system and have 1 be the main gpu or up to 4 of them in crossfire/sli and the rest act as tesla compute cards for bitcoins/folding.
#KilledMyWife
LTT's Resident Black Star
I should get an award for still being here at this point
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1051274
Games with AMD Mantle might support 6 GPUs.
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1051275
Who said it has to be in SLI?
It's no different to having a quadro and a 'gaming oriented' gpu in the same system.
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1051278
1st. Already posted in news section
2nd. It can mine/fold without SLI. SLI can support up to 4 way SLI ONLY (for now, at least)
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1051280
But PCIe 2.0 x1 heavily bottlenecks!
Mining doesn't depend on bandwidth as peviously stated.
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1051599
This is pretty cool you could either get this and use your gpus to mine or you could just a a couple of USB bitcoin miners and put them on a usb hub to mine which are not bad imo. Been quite a while since I seen Parallel and Serial ports on motherboards.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1051773
now figure out how many years itll take to make the BTC you just spent for getting BTC
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1052627
Multi GPU systems for computing is nothing new, we've been using it for mining and folding for years by now. ASRock are the first to specifically target a motherboard towards bitcoin mining though. They're a couple of years late though seeing as existing application specific integrated circuits are so much more efficient now.
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1052673
I was going to say, i wonder if you get the full hash rate if you have 6 of these installed http://www.butterflylabs.com/monarch/ Then I realised something interesting. Does anyone plan to power these cards... Or? Even the 1600w Lepa can't power 6... You would need two and that is just annoying
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1052692
I was thinking of the same device. These might actually go well with these boards. Problem is the costs.
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1052912
6 x GTX 7990.
12 GPU's :P
Don't forget to save space and money for the 2 powersupplies and the private powerstation you will need.
Case: 650D CPU: i5 4670K GPU: GTX 770 Gaming @1306MHz Motherboard: MAXIMUS VI Hero PSU: AX760 CPU Cooler: H100i RAM: 8GB Vengeance Pro @1866MHz Storage: 840 250GB SSD / 2TB Seagate Barracuda 7200.14
https://linustechtips.com/topic/76600-6-gpus-in-a-system/#findComment-1053264
