Will main only affect resolution, and picture quality (colour, blurring). If you've ever tried displaying 1080P via VGA, you'll see the image is blurred a bit in certain areas.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/765277-do-cables-affect-fps/#findComment-9666373
It will not affect how many FPS your hardware can achieve, but it can affect how many FPS is actually sent to the monitor to display. Higher resolution or higher Hz monitors may only support the maximum refresh rate when using a certain cable type (such as DP)
https://linustechtips.com/topic/765277-do-cables-affect-fps/#findComment-9666377
13 minutes ago, WhoSketchy said:
Does using different cables such as HDMI, DVA-D, VGA etc. affect the amount of frames I will get in games...?
Yes, they can - different cable types (HDMI vs DP for example) have different maximum bandwidths, based on the display protocol and protocol version.
Up to 60Hz (60 FPS) they are all pretty much inter-changable, but for example older HDMI cannot do 144Hz - you need the newer standards to support that.
Technically its not just a cable issue - its the end-2-end protocol specification.
https://linustechtips.com/topic/765277-do-cables-affect-fps/#findComment-9666404
The fps he gets in game will remain the same regardless of what cable he uses.
The fps he sees on screen (aka Hz) is what will change.
https://linustechtips.com/topic/765277-do-cables-affect-fps/#findComment-9666407
No but can effect Hz, keep in mind that if you want to go high refresh rate you need DisplayPort or dual link DVI
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/765277-do-cables-affect-fps/#findComment-9666409
Yes, that's true - but given the question was about CABLES i rather think the OP meant "can the number of Frames per Second that are actually drawn onto my screen be different depending on the type of cable?".   The Answer is definitely "YES".
If the OP really meant "Does the FPS counter calculated mathematically inside my PC change based on the cable connecting it to the outside world" then the answer is probably "NO".    I dont think thats what the OP wanted to know (given the question).
https://linustechtips.com/topic/765277-do-cables-affect-fps/#findComment-9666433
This will help you
CPU- Ryzen 9 3900x
CPU Cooler- Artic Liquid Freezer 2 240mm
GPU-  GIGABYTE AORUS GeForce RTX 3070 Ti Master 8G
RAM- CORSAIR VENGEANCE RGB PRO 32GB 3200Mhz
PSU- Cooler Master MasterWatt 650 Watt
HDD- WD Blue 4TB x2
SSD- 1TB WD Blue SN550 NVMe
Case- Custom Made Desk
Motherboard- ASUS ROG Strix B450-F Gaming
Microphone- Blue Snowball Ice
Headphones- Razer Nari Ultimate
Webcam- Logitech c270
Monitors- MSI Optix MAG24C and Acer KA240HQ Abid
Mouse- Corsair Nightsword RGB
Keyboard- Corsair K95 RGB Platinum MX Speed
https://linustechtips.com/topic/765277-do-cables-affect-fps/#findComment-9666454
Sorry for the confusion...! But as previously seen this was what I was asking about: "but it can affect how many FPS is actually sent to the monitor to display"
I was wondering if cables affect how many screens I will receive on my monitor.
I bought a cheap - dvi-d to hdmi cable and compared to my vga to dvi-d it lost some frames, don't know if this was just a random occurrence. (could just be talking nonsense...)
https://linustechtips.com/topic/765277-do-cables-affect-fps/#findComment-9668411
HDMI (especially older versions of HDMI) are a pretty poor choice of cable for Gaming Graphics.   The HDMI standard was limited to 60Hz (60 FPS) for a long time at decent resolutions.   Its only the most recent versions of HDMI to do both good resolution and decent refresh rate.
https://en.wikipedia.org/wiki/HDMI#Version_comparison
This is why native display port was the connector or choice for gaming graphics (at least, was ... HDMI is trying to catch up).
https://en.wikipedia.org/wiki/DisplayPort#Resolution_and_refresh_frequency_limits_for_DisplayPort
https://linustechtips.com/topic/765277-do-cables-affect-fps/#findComment-9671455
Guest
