Alright guys need serious help with Hackintosh...
Solved by Sundanc3,
First of all which Hackintosh method did you use. If you used the tonymacx86 tools I can help.
http://www.tonymacx86.com/374-unibeast-install-os-x-mavericks-any-supported-intel-based-pc.html
You said you had Mavericks installed but the system isn't booting without help from the bootstick. What kexts did you install using Multibeast?
