Hi peeps i got a 7700k last weekend and have it under a evo212 with mk4 stock voltage no OC. It reaches 100c under prime95(i then stopped running it :/ ) and I've seen up to 90 while gaming already. Is this normal for this configuration? I don't have a problem upgrading cooler etc if it's normal but it seems a bit extreme.
Thanks.
https://linustechtips.com/topic/762530-7700k-at-100c/
That's not normal at all. it should be way lower, especially at stock speed.
re-mount the cooler, and make sure you have adequate mounting pressure.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/762530-7700k-at-100c/#findComment-9635542
No it's not normal.
Make sure there is no plastic still on the cooler and that the fan is running.
They try replacing the thermal paste and mounting the cooler again.
https://linustechtips.com/topic/762530-7700k-at-100c/#findComment-9635552
4 minutes ago, Enderman said:
No it's not normal.
Cpu Fans at 100% and check to all. Case fans on like 50% i think.
https://linustechtips.com/topic/762530-7700k-at-100c/#findComment-9635579
Post a screenshot of your temps plz.
https://linustechtips.com/topic/762530-7700k-at-100c/#findComment-9635580
8 minutes ago, Enderman said:
No it's not normal.
I feel like if there was plastic, it probably would have melted
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
https://linustechtips.com/topic/762530-7700k-at-100c/#findComment-9635603
Most plastics melt at higher temperature than 100C.
Also, you would be able to tell if there was melted plastic.
https://linustechtips.com/topic/762530-7700k-at-100c/#findComment-9635638
Thanks.
I bet your "stock" voltage is actually too high.  Common issue with older BIOS and Kaby Lake.  Hell, even new ones aren't getting it right.
https://linustechtips.com/topic/762530-7700k-at-100c/#findComment-9635655
I tried manualy setting my V to 1.24 in the BIOS and then my CPU load wouldn't max out. Pics on the way.
volts included
https://linustechtips.com/topic/762530-7700k-at-100c/#findComment-9635676
Sorry not 100% what you mean :P Does this help?
Yes it does.  Your RAM voltage is really high for a stock or XMP setting.
Humor me and turn off XMP.  Reboot and make sure that your memory speed drops to 2133 and let me know what DRAM Voltage is then.
https://linustechtips.com/topic/762530-7700k-at-100c/#findComment-9635773
Sure thing, thanks for the help
https://linustechtips.com/topic/762530-7700k-at-100c/#findComment-9635780
Seems to be off already, i set the ram to 3200 manually. I'll switch to auto.
https://linustechtips.com/topic/762530-7700k-at-100c/#findComment-9635793
