NZXT S340 Elite vs Fractal Design Define C
RRGT19
  1. NZXT S340 Elite US$ 115.98
    Dimensions W: 203mm H: 474mm D: 432mm
    https://www.nzxt.com/products/s340-elite-black
  2. Fractal Design Define C US$ 117.20
    Case dimensions (LxWxH) - with feet/protrusions/screws: 413 x 210 x 453mm
    http://www.fractal-design.com/home/product/cases/define-series/define-c/define-c-window
Hi,
Which one is better?. I don't use VR.
I like small cases.
Which one is smaller?, I cannot understand how the dimensions work.
2 minutes ago, ELSknutson said:
Get the Define C  Its cheaper and it comes with dust covers all around
Define C is not cheaper, right now on Amazon is more expensive than the NZXT or any other with similar features.
For some reason, Amazon is selling it expensive, I don't know why.
Have you looked at the PHanteks P400s TGE? I'd consider it a bit of a combo between the 2 with a bit extra. I don't know how small you need it but this case isn't unnecessary big. Can bit a full size GPU, up to a 360mm RAD and 2 SSDs, 2 HDDs, no 5.25" bays. Not small enough restrict anything but not big enough to be able to fit a small dog in it with a full PC in it
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
Here's what they look like right next to eachother (also a case review of the define C)
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
Hi,
I like small cases.
And here are 2 pics of my P400s and P400 Tempered glass version. Just so you can see.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
