The Original:
My favorite case of all time is that of the Connection Machine II (CM-2).
This is a supercomputer from 1987 it takes the form of a cube 1.5 meters on a side, divided equally into eight smaller cubes.
In each of these cubes you would find 16 PCB holding 32 CPU's each.
And all of those CPU's had their own activity LED on the front of the case giving you this amazing matrix of flickering LED's:
The LED's:
Sadly my computer wont have a 4096 core CPU, so I needed to think of another way to have the LED's.
I ended up going fot 64 8x8 LED matrix boards that will be controlled by 4 Arduino UNO micro controllers.
The LED's will still be influenced by the PC as I will use the HDD activity pin change the LED's as randomly as possible.
The Case:
I will construct my case out of MDF and it will be 60CM x 60CM.
It will take a while for me to start working on the case as I want to make the LED panels first.
I have however made a rough design in SketchUp:
Front of the case with its glorious 4096 LED's
Closeup on the I/O, 2 of the knobs will be for power and reset and 2 will be for the LED's.
Another awesome feature of the case is the grill between all cubes.
The top of the case will also be ventilated.
I don't really care about the PC hardware (its all about the case), so I will have a section that can slide out on rails which should offer enough place for all the PC hardware.
Planning:
Again, this build will take a while, I just ordered some of the LED panels and a Arduino so I can start on that soon.
Once I'm happy with the LED panels and the design I will start on the actual case.
I'm also constantly getting new ideas, my most recent one was to use a RFID receiver to start the PC by simply dropping my key-chain (containing a RFID) on my desk where the reader will be :P
Respect the Code of Conduct!
>> Feel free to join the unofficial LTT teamspeak 3 server TS3.schnitzel.team <<
>>LTT 10TB+ Topic<< | >>FlexRAID Tutorial<<>>LTT Speed wave<< | >>LTT Communies and Servers<<
https://linustechtips.com/topic/75379-connection-machine-ii-case-mod/
That is going to be epic!!
CPU Ryzen 5 Asrock B350 Pro 4 / MSI RX580 Gaming / RAM 16 Gigs Corsair Vengeance 3000 / HDD 1TB Seagate Barracuda / SSD Samsung 840 120GB / 500GB Samsung SSD / Case Urban S31 / PSU EVGA G2 750w / Os Windows 10 / Keyboard Corsair K70 / Mouse Razer Naga 2013 (Won it from Linus!!
I posted in the wrong section.
o0 the irony :P
build of the week incoming!!! @LinusTech and @Slick
- teamspeak.ltt-unofficial.com
- teamspeak.ltt-unofficial.net
- teamschnitzel.ltt-unofficial.com
- teamschnitzel.ltt-unofficial.net
cpu: Intel sandybridge-E 3930k @ 4.2Ghz
cooler: corsair h100 @ full speed push-pull
motherboard: Asus Rampage IV Extreme
gpu: 2x EVGA GTX660's & 1x EVGA GTX980
ssd: 2x samsung 256GB 840 pro raid 0
ssd: 1x samsung 1TB 840 evo
hdd: WD green 3TB
hdd: Seagate Barracuda 1TB (st1000dm003)
hdd: Seagate Barracuda 1TB (st31000520as)
psu: corsair ax1200i
ram: 8x 4GB corsair platinum @1866mhz
case: coolermaster cosmos II
age: Do the math (summer 2012)
monitors Main: 8x LG 22EA53 1080p 60hz
monitor Extra: 1xiiyama prolite G2773Hs 1080p 120hz 27"
os: windows 7 pro (64-bit)
keyboard: logitech g19
mouse: corsair m60
Lenovo T550
RaspBerry pi webserver:
Status: Offline.
Nas:
StatusOffline.
PC straight to the modem/router/switch/DHCP-Server/... with a 20cm (+-8inch) cat6a patch cable because same price as cat5.
ISP: Telenet (belgium)
Speed: 60Down-4Up (+- 45€/month)
ping to there servers: +-8ms
ping to other Belgians: +-12ms
- wheels for cosmos II
I like it. What is the time scale of this mod going to be?
Wohoha! Build Logs of the Week are comming!!!
Best time-frame estimate I could give would be "months" :P
Sign me up for a truck load of awesome.
Oh my lord, and I'm at the moment struggling with putting text on a video :D Good luck with the build, looks awesome already
Thanks guys :)
I'll take two please.
Build one yourself :P
Ill put the design online when they are done :)
*insert strong language emphasizing enthusiasm*
Dammit, now I want a 4096 core CPU. :D
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
Sweet Jesus, it's epic! Can't wait to see more.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
You said that you would give me the plans  :wub:
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
Oh god, it shall be beautiful.
Loving the idea of this! Cant wait for it!
Build log
CPU: FX-6100 @ 3.9 MOBO: GA 990XA-UD3 RAM: Corsair Vengeance 8GB GPU: HD6870 PSU: Corsair GS800 Case: Bitfenix Outlaw SSD: Samsung 840 250GB HDD: Seagate Barracuda 1TB Cooling: Custom Water-Cooling Peripherals: Keyboard: G710+ Mouse: Steelseries Sensei Steering Wheel: Logitech G27 Sound: Speakers: Logitech x530 Headset: Razer Chimaera Monitor: Benq G2450HM, LG 32" TV
The Original:
The LED's:
The Case:
Planning:
Let me tell ya, you have alot of work ahead of you :)
I started my CM2 in May and only had the panels cut yet, programming the lights and making the panels to hold them takes... yeah, hours :)
Looking forward to your creation, you probably end up finished before me, i do mine in acrylic and smaller, about 45x45cm.
Let me know if you need any information about the CM2, i had contact with the creators of it and have alot of specs if you need anything to complete your project!
A quick hint, you have too much space between each cube in relation to scale. Insert a image on a CM2 and scale the image to get better spacing and the end result will get better too!
I may have scale skp files if they are any help for you.
Have a good trip, will watch your build log!
Dont quote pics! :o
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
Dont quote pics! :o
I quoted the pics i was talking about, not all pics as you can see.
I removed two more to keep it smaller.
I quoted the pics i was talking about, not all pics as you can see.I removed two more to keep it smaller.
Oh, I am completely sorry. I thought you just quoted the pics. My bad.
Cool, nice to see a second one.
the dimensions of my case largely rely on the size of my LED pannels, I will still make the grill smaller but I probably cant make them the same ratio as the original because of the thinness of the wood and the needed space in the case.
But like I said, main focus for now will be the electronics.
Also, feel free to PM me with as much information as possible :)
