1700 vs 7700 for a programmer and gamer
RRGT19
Hi,
I use to create Software and Websites:
  • Adobe Dreamweaver
  • Adobe Fireworks
  • Adobe Photoshop
  • FileZilla
  • Visual Studio
  • Eclipse Neon
  • MySQL Community
I play games at 1080p too, a lot.
Which CPU will be better for me:
  1. 1700 at $329.99
  2. 7700 at $315.99
1700 would be better for your task, 1700 can also game not as well but if you get a x370 mobo and get the cpu up to 4.1 ghz you should be good.
Do the programs you use take advantage of more cores?
Gaming is better on the 7700k than on the 1700.
idk
I don't like the OC and I don't want to spend more money buying an AIO.
1700 stock will also be fine, 8 core cpu will be better for creative work. what is your budget ?
Will you be running those applications and games at the same time? Or just one at a time.
7700 will give higher gaming avg fps if you're just running one at a time.
1700 will handle stuff better if you have a bunch of stuff running at the back ground.
Like say, visual studio + Android Studio with an emulator + 100 Chrome tabs + "insert your avg mmo game here", the 1700 will fair better in that.
Though I will add that the X370 platform is still really immature. So there will bound to be some incompatibility issues. High speed ram compatibility isn't very good right now. Its similar to the state that X99 was with ddr4 3 years ago.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
a 6800 or 5820k will be better for pro work
The 7700 will compile your stuff significantly faster.
Seriously, stop recommending your old CPU 50 times a day.
Ew, X99. That architecture's EOL according to Intel anyway, X299 HEDT coming soon
idk
I have Visual Studio, Eclipse, Chrome, Music, opened.... and a game too
x99 architecture EOL thats a new one still time away from x299
l i7 5930k | Rampage V Extreme | Corsair H110i GTX | G.Skill Ripjaws 4 16GB DDR4 3000Mhz | EVGA GTX 1070 Superclocked ACX 3.0 | EVGA SuperNova 750w G2 | Samsung 960 Evo 250GB l Samsung 950 Pro 256GB | Samsung 850 EVO 250GB | Samsung 840 EVO 250GB | 1 TB WD Red | Corsair 900D |
Evolution - https://uk.pcpartpicker.com/list/LbJq9W
CPU-Z Validation - http://valid.x86.fr/3dxmew
HEDT gets replaced every two years, that's normal. x79 was replaced after Xeon v1/v2, x99 replaced after v3/v4..
idk
I'd get the 1700 tbh. 7700k only beats the 1700 in gaming because of significantly higher clocks. The 7700 is only at 3.6ghz, and it's locked.
Gaming performance should  be similar ( especially if you aren't running an extremely high end gpu like the 1080 or 1080ti), and you'll have vastly better productivity performance.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
I will have a GTX1080Ti, I'm waiting to receive it.
If you arent overclocking id probably take the 1700 - 7700k excels with gaming performance when running high boost/overclocks
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
1700 then. I would still apply a mild OC (no need for an AIO since that chip only has a TDP of 65w), but no need for anything crazy.
Current LTT F@H Rank: 90    Score: 2,503,680,659    Stats
Yes, I have 9 monitors.
My main PC (Hybrid Windows 10/Arch Linux):
OS: Arch Linux w/ XFCE DE (VFIO-Patched Kernel) as host OS, windows 10 as guest
CPU: Ryzen 9 3900X w/PBO on (6c 12t for host, 6c 12t for guest)
Cooler: Noctua NH-D15
Mobo: Asus X470-F Gaming
RAM: 32GB G-Skill Ripjaws V @ 3200MHz (12GB for host, 20GB for guest)
GPU: Guest: EVGA RTX 3070 FTW3 ULTRA Host: 2x Radeon HD 8470
PSU: EVGA G2 650W
SSDs: Guest: Samsung 850 evo 120 GB, Samsung 860 evo 1TB Host: Samsung 970 evo 500GB NVME
HDD: Guest: WD Caviar Blue 1 TB
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Other: White LED strip to illuminate the interior. Extra fractal intake fan for positive pressure.
unRAID server (Plex, Windows 10 VM, NAS, Duplicati, game servers):
OS: unRAID 6.11.2
CPU: Ryzen R7 2700x @ Stock
Cooler: Noctua NH-U9S
Mobo: Asus Prime X470-Pro
RAM: 16GB G-Skill Ripjaws V + 16GB Hyperx Fury Black @ stock
GPU: EVGA GTX 1080 FTW2
PSU: EVGA G3 850W
SSD: Samsung 970 evo NVME 250GB, Samsung 860 evo SATA 1TB
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity)
Case: Sillverstone GD08B
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
Details: 12GB ram, GTX 1080, USB card passed through to windows 10 VM. VM's OS drive is the SATA SSD. Rest of resources are for Plex, Duplicati, Spaghettidetective, Nextcloud, and game servers.
1700 get it up to 4ghz, should be fine because of the 65w
are u playing at 4k or 1440p ?
If 1080p every cpu will bottleneck the 1080ti without vsync
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
2 hours ago, RodoGodo19 said:
-snip-
I'd also recommend the 7700K. Programming honestly doesn't use that much CPU power. I can code on my mid range laptop pretty easily...The 7700K would game a bit better too.
The faster single core speed would help you more with coding. I have a lot of stuff open on my 2700K and I can't see much of a issue with coding.
Even for gaming you'll still get like 100+ frames with the 1700 + 1080Ti.
No reason to worry.
[ Cruel Angel ]:     Exterior  -   BENQ XL2420T   |   SteelSeries MLG Sensei   |   Corsair K70 RED   |   Corsair 900D  |        CPU:    -   4.7Ghz @ 1.425v             |
                             Interior    -   i7 4770k   |    Maximus VI Formula    |   Corsair Vengeance Pro 16GB    |   ASUS GTX 980 Strix SLIx2  |  840 Pro 512Gb    |    WD Black 2TB  |           RAM:   -   2400Mhz OC @ 1.650v    |
                             Cooling   -   XSPC 120mm x7 Total Radiator Space   |   XSPC RayStorm    |    PrimoChill Tubing/Res  |        GPU:   -   1000Mhz @ 1.158            |
On 3/12/2017 at 11:44 PM, RodoGodo19 said:
Hi,
  • Adobe Dreamweaver
  • Adobe Fireworks
  • Adobe Photoshop
  • FileZilla
  • Visual Studio
  • Eclipse Neon
  • MySQL Community
  1. 1700 at $329.99
  2. 7700 at $315.99
To give you an idea, my 4790k is clocked at 4.5GHz and is more than twice as slow when exporting in adobe premiere compared to my stock 1700x.  Gaming wise, it falls behind 5-10%.
Hi guys,
I was watching the prices on Newegg and for $420 you get the 1700 and the MSI B350. Is a nice deal.
I have a monitor 24" 1080p 60hz.
GTX1080Ti
Samsung 960 EVO
For Intel is $464 and you get 7700 and ASUS H270F.
I have read that Windows 10 is gonna bring an update to handle better the AMD's processor.
The thing is, again, I create software and I need the best performance possible when I have 2-4 programs opened. Also, I like to play games at 60FPS constant at max settings too.
Again, which combo do you think will be better for me?, I'm confused.
Even if programming is single core, the price difference is $44.
  1. 1700 - MSI B350 / $420
  2. 7700 - ASUS H270F / $464
3 minutes ago, RodoGodo19 said:
Hi guys,
GTX1080Ti
Samsung 960 EVO
What do you have now? Id be tempted to get a 1440P monitor, 1080ti on 1080p O.o
Ryzen Ram Guide
nothing, just a samsung 960 evo.
I don't know if the programs I use will benefit from more cores or not, I don't want to have delays because of the CPU.
Well a 1080ti and either of the 7700k or 1700 will be MORE than enough for 1080P 60hz - if you're set on 1080P get the 1700 it wont make a difference and cores will help in software
Ryzen Ram Guide
