What is the difference between 2.4G and 5G
keavlar
Hello every one.
I wonder in basic terms,what the difference between 2.4G and 5G network?!
I have at home couple devices , which looks like, does not support 5G.
So i wanted to know, if that could cause speed difference between devices, located on same range from the modem?!
CPU - AMD 5800XMotherboard - ROG STRIX B550-E GAMING , Memory  - G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 ,
GPU - NVIDIA GeForce RTX 3080 Ti MSI SUPRIM X 12G,  Case - 4000D AIRFLOW Tempered Glass Mid - Tower ATX Case - Black ,
Storage - Samsung 970 EvoPlus 500GB - Samsung 870 EVO 1TB + 6TB HDD,
PSU - Corsair HX1000 , Display -  ASUS TUF Gaming VG27A 165HZ + Dell 24 UltraSharp Monitor , Cooling - Noctua NH-D15 Black ,
Keyboard - Razer Stalker , Mouse - Logitec G502 Wireless , Operating System - Win 10 Pro ,
Sound - Logitech Z906 5.1 THX Surround Sound Speaker System
5 GHz has faster speed but less connection strength, 2.4 GHz has slower speed but longer connection strength.
The geek himself.
Thank you !!!
16 minutes ago, nerdslayer1 said:
Than you 2 . I just can't watch the video now, so i preferred a less time killer way to get answer xD
Why not all devices support 5G . and what i need to look in preferences to see, if it does ?!
Short Answer is: Older Devices Came with 2.4GHz, newer devices since 2014 about come with 5GHz.
The geek himself.
Also 802.11a, 802.11n and 802.11ac all work on 5GHz, but with 802.11n it's optional. This means that as most current routers are 802.11n models, you will probably need to find out if yours has a 5GHz radio in addition to the more common 2.4GHz one.
The geek himself.
Tell me please.
If i understand from preferences , of this device , it have all this 802.11s/n/ac  but don't support 5G??!!
Is that correct ?
Tell me please.
Is that correct ?
It depends, I can't really explain.
The geek himself.
You can't explain what ??
I am just asking, if its true that it does not have 5G?!  Right?
802.11a, 802.11n and 802.11ac, if those bands support your device which should be on the manufacturer website, then you should be fine.
The geek himself.
Well ::
Wireless Standards IEEE 802.11n, IEEE 802.11g, IEEE 802.11b
Frequency 2.400-2.4835GHz
So.. i guess, it does not ??!!
xD its all i'am trying to understand .or  cause it does not have 802.11 a /ac , it dies not have 5G ?
Well ::
It is not compatible.
The geek himself.
Only ones I know of that support 5ghz is 802.11AC everything else N G etc downward does not and was to my understanding built for 2.4. Almsot every wireless device states the 802.11 standards it supports on is packaging or in a manual.
So , if i understand correct , i need a device, that support 802.11AC for 5G?
for the 5ghz signal yes. If you mean 5G like a cell tower system no idea. Thats an entirely different set of protocols.
No no ,, just for home internet. i have modem that have 5G , but 1 px does not support it. Just wanted to make sure.
then yes 802.11AC will run it  anything with 802.11 A, B, G or N will not.
