I am currently planning to buy a second Nvidia GTX 660 Ti (as of right now the Gigabyte GeForce GTX 660 Ti OC), and I was wondering if I would need to upgrade my power supply.
Here are my current specifications:
CPU: Intel Core i7-2600K @ 3.4 GHz
Cooling: A CoolIT liquid cooler, the exact model has been lost in time.
GPU: EVGA GeForce GTX 660 Ti FTW Sig. 2
RAM: 16GB of Kingston HyperX (1600 Mhz)
SSD1: 120 GB
SSD2: 256 GB
SSD3: 32 GB
HDD: 1 TB
MOBO: Gigabyte Z68A-D3H-B3
PSU: Raidmax RX-850ae (850 watts)
Additionally: I have a basic 24x CD/DVD drive, and a 5.25" fan controller.
If I add a Gigabyte GeForce GTX 660 Ti OC what size power supply should I get as far as wattage goes?  Any specific models you would suggest would help too.  I am currently looking at a Seasonic PLATINUM-1000 (1000 watt) power supply, which seems like a good one, but it may be more than I need.
Also, if you disagree with my graphics card choice and have something that is similar to the power of the discontinued EVGA GeForce GTX 660 Ti FTW Sig. 2, feel free to let me know.
Thanks in advance!
https://linustechtips.com/topic/75089-how-powerful-a-psu-do-i-need/
I don't think so!
| Case: NZXT Tempest 210 | CPU: Intel Core i5 3570K @ 3.9 Ghz | GPU: ASUS ROG STRIX GTX 1070 | RAM: Crucial Ballistix Tactical 8GB |
| Mouse: Zowie FK1 | Monitor: Acer 21.5' | Keyboard: CoolerMaster Stealth w/ Brown Switches |
#KilledMyWife - #LinusButtPlug - #1080penis
You should be just fine with an 850 watt power supply for 2 660ti cards. I can't imagine that system pulling more than 675 watts under heavy load :)
Edit:
Congratulations on your first post! Welcome to the forum :)
CPU Overclocking Database <------- Over 275 submissions, and over 40,000 views!
GPU Overclocking Database
Your 850w should be fine, maybe buy a better quality 850w as 1000w is overkill, my friend has a similar build to you but with 2x 580's and it uses around 850w so yours would use less then that.
Keep your psu or buy a better quality version of the same wattage
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
You will be fine. You could probably get a way with 680's in SLI on an 850, I wouldn't do it, but 660's no problem!
I don't think so!
Okay, thank you!
Edit:
Thank you!  Seems like a great forum so far!
I may do that, because Raidmax is not exactly what I would now consider a "trusted" power supply brand.  Does either Seasonic or Corsair sound good to you?  Any other really good brands?  Also, thanks for the info!
A 750w would be enough to power these cards so your Raidmax psu should be able to handle this as it is more than enough to power this.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
Okay, thank you!
Yes they are my personal favorite and make beast psu's, if you want a quiet build the RM series from corsair are good, but anything from those two are good
Okay, thank you!
Corsair PSUs are rebranded Seasonics if i remember correctly (so both are great!). I would also recommend cooler master, and Be Quiet! Power supplies! :)
750watt and less if your aiming to be efficient as possible get the seasonic fanless 550w-460w psu its expensive however its 80+platinum meaning........ well pretty darn great power delivery or grab a 650w Corsair RM series.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
Raidmax are listed as a dangerous brand and could probably only delivery 600W or so, definitely replace it, however a good 850W should run it fine
http://www.eggxpert.com/forums/thread/323050.aspx
CPU: Intel Core i7-4790k @ 4.7 1.3v  with a Corsair H80 w/Dual SP120s - Motherboard: MSI Z97 gaming 5 - RAM: 4x4 G.Skill Ripjaws X @ 1600 - GPU: Dual PowerColour R9 290- SSD: Samsung NVME SM951 256GB-- PSU: Corsair RM 1000  - Case: NZXT H440 Black/red - Keyboard: Coolermaster CM storm Quickfire TK, Cherry MX blues - Mouse: Logitech G502 - Heaphones: Beyerdynamic DT 770 - Monitors: 3x VE248H Eyefinity 1080P -  Phone: iPhone 6S Plus               Please post your specifications in your post, signature or even better, system page on your profile!
Thanks for all the various suggestions and Raidmax jokes.  I plan on staying at 850 watts, but buying a new, better-quality power supply.
Really helpful, thank you!
Only about half of less are Seasonic rebrand. The XFX PSU (seasonic rebrand) I linked before is probably his best option in terms of what he needs, price, and quality.
No, I think it should be able to deliver at least 800w, I don't think it's terrible but it is not a trustworthy brand at all, I wouldn't so much as consider buying a PSU from them. Running the kind of hardware OP is going to be putting on it I would not even take the slightest risk. A small investment can potentially save a lot of cash.
Error: 410
http://www.ebay.com/itm/EVGA-2GB-GeForce-GTX-660-Ti-FTW-Signature-2-GDDR5-02G-P4-3664-KR-Video-Card-/321247610987?pt=PCC_Video_TV_Cards&hash=item4acbd9886b
Get this card, and then nothing below 750W. I would recommend anything from Seasonic, Fractal Design or Silverstone. Also, some from Corsair.
Not all Corsair PSU's are rebranded Seasonics, some are also rebranded ChannelWell PSU's(which are also good).
Seasonic, XFX and Corsair are the brands I'd recommend.
