{AIOs}  {Value} =
If you make a post contradicting mine that doesn't directly address my claims, or cites 'facts' without evidence, I'm probably not going to bother responding to it, because you probably didn't bother reading my post properly, and because life is too short. It doesn't mean I don't have an answer for you. It means I'm not dignifying you with a response.
28 minutes ago, Droidbot said:
best value?
http://pcpartpicker.com/product/hQ7CmG/lepa-cpu-cooler-lpwac240hf
it's the cheapest 240mm cooler around
how is it that cheap? holy crap a $60 240 AIO!
Builds:
4 minutes ago, Droidbot said:
lots o' leaks according to newegg reviews, I'd still invest the extra $20 into a H100i just to be safe
lmao id just get duct tape and tape it shut instead :P
Builds:
46 minutes ago, RastaburyOG said:
Any opinions on the best bang-for-the-buck (not BEST I'm not loaded) AIO dual rad CPU cooler? Any fan size.
well, AIO's are not the way to go if you're looking for "bang for the buck" cooling.... but if you are looking or cooling:dollar ratio and it MUST be an AIO, then get the cheapest 240mm you can find as it will result in the best cooling:dollar. Good ones that are also cheap are the LEPA 240 aqua changer, CoolerMaster master Liquid Pro, and the Enermax Liqmax II 240. Beyond that you start getting into more premium ones which are a fair bit more expensive. There are also other cheap ones, but I've heard good things about the ones I've mentioned here (not to say the others are bad, I've just not heard much about them)
https://pcpartpicker.com/products/cpu-cooler/#W=10240&sort=a6&page=1
Consult that list and just purchase the cheapest one if you're looking for "bang for the buck"
1 hour ago, nerdslayer1 said:
price range? AIOs are not really cheap option, if you want a overpowered cooler that will last you a long time get a dark pro 3 or a DH 15.
Problem is, those are both enormous. Like in my case, I want a better cooler but I have to get a 240mm AIO 'cause the bigger air coolers just won't fit.
Laptop: Asus GA502DU
RAM: 16GB DDR4 | CPU: Ryzen 3750H | GPU: GTX 1660ti
