If your case supports a card with 2 fans, I'd do that. 6GB is better for most new games. Alternatively you could get the RX480, slightly cheaper for as good or better performance
RGB Build Post 2019--- Rainbow 馃 2020---Velka 5 V2.0 Build 2021
Purple Build Post ---Blue Build Post---Blue Build Post 2018---Project ITNOS
CPUAMDR7 7800X3D聽 聽聽MotherboardAsrock B650E Taichi Lite聽 聽聽RAMCorsair Vengeance RGB 32GB 5200mhz聽聽 聽GPUASUS RTX4080 STRIX聽
CaseFractal Torrent聽 聽StorageSamsung 980Pro 2TB, Crucial P3 Plus 4TB x2,聽 聽 聽PSUCorsair RM1000x聽 聽聽CoolingDeepcool AK620
https://linustechtips.com/topic/735567-video-card-help/#findComment-9337996
Personal Desktop":
CPU: Intel Core i7 10700K @5ghz |~|Cooling: bq! Dark Rock Pro 4 |~|聽MOBO: Gigabyte Z490UD ATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: RX 6900XT Sapphire Nitro+ |~| PSU: Corsair TX650M 80Plus Gold |~| Boot:聽 SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~|Case: Fractal Design Meshify C Mini|~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro.
Luna, the temporary Desktop:
CPU: AMD R9 7950XT聽 |~|Cooling: bq! Dark Rock 4 Pro|~|聽MOBO: Gigabyte Aorus Master |~| RAM:聽32G Kingston HyperX |~| GPU: AMD Radeon RX 7900XTX (Reference)|~| PSU:聽Corsair HX1000 80+ Platinum|~| Windows Boot Drive: 2x 512GB (1TB total) Plextor SATA SSD (RAID0 volume)聽|~| Linux Boot Drive: 500GB Kingston A2000|~| Storage: 4TB WD Black HDD聽|~|Case: Cooler Master Silencio S600|~| Display 1 (leftmost): Eizo (unknown model) 1920x1080 IPS @ 60Hz|~| Display 2聽(center): BenQ ZOWIE XL2540 1920x1080 TN @ 240Hz|~| Display 3 (rightmost): Wacom Cintiq Pro 24 3840x2160 IPS @ 60Hz 10-bit聽|~| OS: Windows 10 Pro (games / art) + Linux (distro: NixOS;聽programming and daily driver)
https://linustechtips.com/topic/735567-video-card-help/#findComment-9338065
15 minutes ago, Princess Cadence said:
I swear to god that things needs to be called The Over Compensatior聽lol
https://linustechtips.com/topic/735567-video-card-help/#findComment-9338150
30 minutes ago, Awsomnes said:
Hello! I was wondering if i should get a gtx 1060 3gb or a 1060 6gb, of course the 6gb is better but is it worth it? And if a get a mini card thats like with 1 fan or should i get a full card with well 2 fans? you get it.
More is moar better. The 3GB has a few less cuda cores and less fans is less cooling capacity, and while you might not need it now, it's nice to have lest you have to buy a new GPU down the road.
Yours faithfully
https://linustechtips.com/topic/735567-video-card-help/#findComment-9338160
