1080p monitor
Bruno_A
Hey guys, I'm building a gaming pc, a budget gaming pc and I have everything but the motherboard, which is being held by customs, but anyway, I've got everything, including a keyboard and a new 1080p monitor and I'm now using it with my laptop via HDMI and I notice FPS drops when playing CS:GO, I play CS:GO on 1024x768p 4:3 stretched and when I'm using my laptop alone, it's not a very fluid experience and the FPS are super unstable, but still playable, but this changes when I play with my 1080p monitor on 1024x768p, which is the same resolution I play on my laptop's screen. Why this happens?
Many thanks, Bruno.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
10 minutes ago, TechGuy007 said:
does it drop in other games too ? csgo is retarded
I can't test it right now, I only play cs:go. But the same happened when I played cs:go on my 1360x768p TV via VGA.
