what monitor for a 1060?
Watashi
Hello, I was concerned that a higher refresh rate on a monitor may call for a nicer graphics card, this would influence me to buy a different monitor. Benchmarks for the 1060 at 1080p is more than good for me. What monitor do you guys think I should use and why? Originally I was thinking about going with this one https://www.amazon.com/gp/product/B01C05C1OK?tag=linus21-20
4 hours ago, nerdslayer1 said:
that's a good monitor go for it
I thought so :D
A GTX 1060 is more than enough to handle a 144hz 1080p monitor.
i5-7600 / GTX 1060 6GB / 16 GB DDR4
4 hours ago, Jale/Aeroplus said:
Your card is more than enough to handle a 144hz 1080p monitor.
Is it harder for a GPU to push 60 fps at higher framerates? That is something that I have never thought about before
Looks like a fine monitor
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
It all depends on the FPS you get in games. 144 Hz = 144 FPS, although there can be some exceptions sometimes.
So that's the reason why G-Sync is needed. Because there is no way a 1060 is getting 144 FPS xD
