Replacement Speakers for f150
Solved by terrytek,
3 minutes ago, eatitmonkeyboy said:Would this http://www.crutchfield.com/p_105KDR988B/JVC-KD-R988BTS.html
work well with 4 of these http://www.crutchfield.com/p_500SPS517/Alpine-SPS-517.html
Also well these be good well rounded speakers like give me some bass for rap and be good for some classic rock? sorry for all the questions. I can do computers all day but speakers just no clue.
the stereo has its own amp with 4 channels, and unless your car has only those 4 speakers, it should be more than ok for you. and i don't think rounded speakers will fit, because i'm sure your stock speakers are oval, so only oval speakers will fit in the housing. but regardless of shape, normally larger speakers allow for more bass, but mostly depends on the brand.
