Hi guys,
new to this forum but been watching linus tech tips for awhile an thought it's about time I brought my pc up to scratch, it's been sitting around doing nothing for about 18 months now an I built it about 4 years ago, I've booted it up today an everything works good just my ssd has only 3gb left so I'm thinking of doing a fresh install and go from there and weather to upgrade hardware while in at it.
My current set up is:
Motherboard z77-ds3h
CPU intel i5 3750K 3.4ghz
CPU cooler zalman cnps10x
Ram corsair 8gb 4x2gb 1600mhz 1.65v
Gpu msi r7770
Ssd corsair force 120gb
hdd 2tb
Psu tagen 480w
Case zalman z11 plus
all I won't to do is have a pc that will runs games ok as I'm not a heavy gamer and run solidworks (CAD) and for my daughter an wife to use office, so dunno weather just add a extra ssd for programs and maybe upgrade gpu an psu? I'd like to run dual monitors too but unsure if current card would be ok with it as it dos have hdmi and dvi-I port but not sure if it's best to run two monitors using the same cables, i.e. 2 hdmi or 2 dvi, or weather ruining the same gpu with hdmi in one monitor and dvi in the other.
Id love for some feedback as to what people think is best to do
Regards
Sam
https://linustechtips.com/topic/716927-do-i-upgrade-hardware-or-not/
A new GPU would be nice.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
4 minutes ago, Sam0117 said:
Regards
Sam
Getting a gpu would be nice for you. Also, having more space on ssd, either by upgrade or by reformatting and starting over. Finally, depending on how much you would be multitasking, having more ram, if you could just slot two more 4gb sticks in, would be nice. Have a great day!
As #muricaparrotgang's founder, I invite you to join our ranks today.
"My name is Legion 'Murica Parrot Gang, for we are many."
(We actually welcome all forms of animated parrot gifs.)
The artist formerly known as Aelar_Nailo.
Profile Pic designed by the very lovely @Red :)!
Really all you need is a better GPU and a PSU is practically a necessity. I wouldn't trust that unit as far as I can throw it.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
The CPU is totally fine for now and upgrading it would be silly since then you would need a new mobo+ram as well for very negligible performance increases with what youre throwing at the computer
The current GPU will have no problem running 2 monitors, and using different cables makes no difference. But an upgrade would be nice for gaming. If you upgrade the GPU, definitely go for a new PSU as well.
When in doubt, re-format.
I would go for something like an RX 470 (they are great especially if you can find them as low as $149 after rebates) and a new PSU, a 240 GB SSD wouldn't be a bad idea either.
Main PC: i5 4590 @ 3.5 GHz ♦ RX 480 Armor OC ♦ 16 GB DDR3 ♦ GA-Z97-HD3 ♦ 120 GB 840 EVO ♦ 120 GB Intel 520 ♦ W10 Home
Scrapyard PC: Xeon X5460 @ 3.8 GHz ♦ HD 7870 ♦ 8 GB DDR2 ♦ GA-P35-DS3L ♦ 80 GB Intel 320 ♦ 160 GB WD Caviar SE ♦ W10 Home
36 minutes ago, Sam0117 said:
Just slap in an RX 470 and you should be good, the CPU is fine
next step would be some kind of free-sync display
Well I thought about the ram as I got 4 slots but it's got a seperate fan block for the 4 sticks of ram so changing them to get 16 or 32gb would be a good idea.
16 minutes ago, Sam0117 said:
A free-sync display?? I'll google it lol
A replacement for V-sync to fix screen tearing, unlike G-sync, it doesn't usually massively increase the cost of a display
Depends on the type of display you'd want, this one's 27" 4k 60hz TN, shouldn't ever have to replace a 4k display really, of course a 470 can't run most games at high-ultra 4k, but 1080p scales perfectly with it
IPS is a bit nicer of course though, adds about $100
PCPartPicker part list: https://pcpartpicker.com/list/3jtG2R
Price breakdown by merchant: https://pcpartpicker.com/list/3jtG2R/by_merchant/
Video Card: MSI Radeon RX 470 4GB ARMOR OC Video Card  ($173.98 @ Newegg)
Monitor: AOC U2879VF 28.0" 3840x2160 60Hz Monitor  ($299.99 @ Best Buy)
Total: $473.97
Generated by PCPartPicker 2017-01-03 15:56 EST-0500
