ShadowProxy on EC2 - Problem connecting to proxy
Hi I am not sure if anyone out there is familiar setting up shadowproxy on AWS EC2 instance, I have trouble connecting to my server as it gives me connection error and when i try to ping my public IP of the instance i get request timeout, all the configuration are same to the guide apart from ip range it just a single port 8000, i have tired using a different port but the same problem. The proxy client also gives me timeout error in the log area, i presume the actual shadowproxy is working as it started without any errors in the .log file.
Error:
System.Reflection.TargetInvocationException: An exception occurred during the operation, making the result invalid.  Check InnerException for exception details. ---> System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.IO.IOException: Authentication failed because the remote party has closed the transport stream.
   at System.Net.TlsStream.EndWrite(IAsyncResult asyncResult)
   at System.Net.PooledStream.EndWrite(IAsyncResult asyncResult)
   at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar)
   --- End of inner exception stack trace ---
   at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
   at System.Net.WebClient.GetWebResponse(WebRequest request, IAsyncResult result)
   at System.Net.WebClient.DownloadBitsResponseCallback(IAsyncResult result)
   at System.ComponentModel.AsyncCompletedEventArgs.RaiseExceptionIfNecessary()
   at Shadowsocks.Controller.UpdateChecker.http_DownloadStringCompleted(Object sender, DownloadStringCompletedEventArgs e)
Additional lines in shadowproxy lines:
    "auth": true
Guide I followed:
https://www.vpndada.com/how-to-setup-shadowsocks-server-on-amazon-ec2/
Magical Pineapples
You need to allow ICMP to get ping response.
In security group, add ICMP rule (custom or all, up to you). If custom, then Echo Reply.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
Dope but doesn't really fix the main problem.
Magical Pineapples
