Memory clock stuck at 150MHz
Solved by Drak3,
Revert drivers. Check if issue is fixed.
If yes:
- Create system image.
Try a fresh install of ReLive drivers.
- If problem returns, revert and do not use new drivers.
- If problem doesn't return, then it was just a bad install.
If no, try the following (in any order):
- Reseat the card.
- Test card in another build (probably a friend's)
- Swapping the BIOS if the card has a dualBIOS switch
Panic
