SSD help
xephoneration
So I am finishing up upgrading my PC. I just bought a 1070 and I am looking to upgrade my storage. I am torn between the Patriot Hellfire 240gb m.2 and the samsung 850 evo 500gb
This really should not be hard since they are pretty much the same price and the 850 would be a no brainier to go with. though im looking at the different speeds of both and the, please correct me if I am wrong, the patriot is faster. Anyways my budget is $150 I am looking for a SSD or an NVME or both, to put my OS and some of my most played games on.
Computer specs are in the description if you are curious I need to update it since I now have 24gb of DDR4 ram
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
If you have a lot of games/programs that you want to put on the ssd then the 850 evo 500gb. would be the best choice. But if you only want to put your OS and a couple of games, then the Patriot would be a better upgrade.
If you want M.2, I'd get MX300 525GB. Great controller that scales well with deep queues like the 850 EVO but gives more for the money.
750GB 2.5" is 170 and the 525GB M.2 is 125. @xephoneration
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
http://pcpartpicker.com/product/34Nypg/crucial-mx300-525gb-m2-2280-solid-state-drive-ct525mx300ssd4
http://pcpartpicker.com/product/VrH48d/samsung-internal-hard-drive-mzn5e500bw
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
I would go for more space over the m.2
I'm just a random teenager from New Jersey. Why would you listen to me?
m2 vs sata. get the m2. i have a samsung 850 evo. I'm happy with it after several years of using an intel SSD. 5 year warranty too
ψ ︿_____︿_ψ_
