Radeon settings wont run becuase Qt5().dll is missing
Solved by jools,
download Guru3D's DDU and clean out those old drivers. then get a fresh copy (re-download amd drivers) then install , check amd folder for QT files(I don't know where) to see if they installed . PS don't install Gaming Evolved there just adverts/feedback
Featured Topics
shift8 ·
Posted in Networking2 -
Premoz1 ·
Posted in General Discussion3 -
3
2
Cheki ·
Posted in Troubleshooting2 -
5
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
